West_Coaster Posted August 25, 2020 Share Posted August 25, 2020 Deleted, found what I needed with the search finally. Link to comment
TEWKS Posted August 25, 2020 Share Posted August 25, 2020 This should get you all the tools you’ll need. http://www.jimvonbaden.com/Tool Lists R1200 CamHead.doc And this should tell you how to use them. http://www.jimvonbaden.com/Camhead_R1200_2010-2013.html 1 Link to comment
Indy Dave Posted August 26, 2020 Share Posted August 26, 2020 12 hours ago, West_Coaster said: Deleted, found what I needed with the search finally. What did you end up getting? Link to comment
West_Coaster Posted August 26, 2020 Author Share Posted August 26, 2020 16 hours ago, Indy Dave said: What did you end up getting? Turns out I have almost everything I need to service my bike. Not sure what I'm going to do about turning off the service light, a $300 GS911 seems expensive to remove the word service from the display. Hard to believe there is no way outside a dealer to do it, very inconvenient of BMW. Link to comment
BrianM Posted August 27, 2020 Share Posted August 27, 2020 I never reset the service light on my 2011. Traded it in with 50,000 miles. Link to comment
6speedTi Posted August 27, 2020 Share Posted August 27, 2020 1 hour ago, West_Coaster said: Turns out I have almost everything I need to service my bike. Not sure what I'm going to do about turning off the service light, a $300 GS911 seems expensive to remove the word service from the display. Hard to believe there is no way outside a dealer to do it, very inconvenient of BMW. If your going to do all the servicing on your bike then an investment for a GS911 is in order. It's a tool like a torque wrench or multimeter. With the GS911 you can scan and troubleshoot faults without shotgun troubleshooting. At the end of the day it will be your decision. Link to comment
Hank in WV Posted August 27, 2020 Share Posted August 27, 2020 Will the same GS911 work on all models from the oil heads to the present? Link to comment
Oldrider51 Posted August 27, 2020 Share Posted August 27, 2020 The GS911 will work with any BMW but you must have the correct connector. The newer BMW models use the standard OBDIi connector as I understand while older models, I believe 2016 and older still use the round connector. At least this is true for my 16 R1200RS. I have the newer model GS911 and use it on my 04 R1100S and my 16. Link to comment
wbw6cos Posted August 28, 2020 Share Posted August 28, 2020 There is an adapter plug available to use on the round connector, which is from the OBDII end of the GS 911. IF I recall, you simply select the GS 911 you need with the correct connector. My RT needs the OBDII and my old school 2000 model C needs the round one. The latest GS 911 will cover the Oilheads to present, but look on the FAQ section of the website to confirm the model coverage; they have a list of bikes and details what the GS 911 can do for those models. Link to comment
szurszewski Posted August 28, 2020 Share Posted August 28, 2020 Also make sure you have a plan for what device you will use with the GS911 - there are wired, WiFi and Bluetooth versions. Using a Mac vs pc vs Android will make a difference in how you access the information from the GS911. Link to comment
Indy Dave Posted August 28, 2020 Share Posted August 28, 2020 I have a Genuine Yellow Hexcode GS911 (not China knockoff), USB model with 8 open slots that works for your bike that I no longer need. PM me if you're interested. Link to comment
Gage Posted August 29, 2020 Share Posted August 29, 2020 Before you get the gs911 you should research the motoscan app. The app is $50 plus a cable and obd reader you’re at like $110 for the same functionality. i was about to get the gs911 until I found the app which doesn’t require a pc to use. no vin limit either Link to comment
