MachineJoe Posted August 14, 2020 Share Posted August 14, 2020 My neighborhood cycle shop couldn't balance my rear tire so I made this adapter (from the hexhead group) but changed it by installing bearings. IMG_2622.MOV Link to comment
dirtrider Posted August 14, 2020 Share Posted August 14, 2020 1 hour ago, MachineJoe said: My neighborhood cycle shop couldn't balance my rear tire so I made this adapter (from the hexhead group) but changed it by installing bearings. IMG_2622.MOV 1.4 MB · 8 downloads Afternoon Joe Looks good, hope those a very tight tolerance bearings as just little play in those brings will allow the wheel to not stay perfectly centered on it's true center. Usually those are made so that the shaft stays tight to the wheel center then the entire shaft/wheel spins on the bearings (that way any bearing play or clearance doesn't change the true wheel center vs the axle center). Link to comment
MachineJoe Posted August 14, 2020 Author Share Posted August 14, 2020 58 minutes ago, dirtrider said: Afternoon Joe Looks good, hope those a very tight tolerance bearings as just little play in those brings will allow the wheel to not stay perfectly centered on it's true center. Usually those are made so that the shaft stays tight to the wheel center then the entire shaft/wheel spins on the bearings (that way any bearing play or clearance doesn't change the true wheel center vs the axle center). Hello dirtrider, Bearings are pretty solid and machining concentricity was held to .0005” on bolt circle to bearing centers. Link to comment
KMC1 Posted August 23, 2020 Share Posted August 23, 2020 On 8/14/2020 at 11:02 AM, MachineJoe said: My neighborhood cycle shop couldn't balance my rear tire so I made this adapter (from the hexhead group) but changed it by installing bearings. IMG_2622.MOV 1.4 MB · 25 downloads Sweet! I want to get something like this for the RTW as I usually do my own tires. That's nice and gives me shop envy too lol 1 Link to comment
Rougarou Posted August 24, 2020 Share Posted August 24, 2020 I haven't balanced a rear tire in the last ten years and nearly 200k miles on all four bikes I've had,......don't even know why I balance the front. 1 1 Link to comment
AZgman Posted August 24, 2020 Share Posted August 24, 2020 For those without a machine shop: https://www.wunderlichamerica.com/wheel-balancer-adapter-14006.html Just check the hole ID with whatever balancing stand axle you currently have 1 Link to comment
