RT Pilot Posted May 7, 2006 Share Posted May 7, 2006 Well, today I removed the wheels from my 04 RT, thinking that I'd get the new tires put on. In the process of removing them (1st time)I completely depress the rear brake after removing the rear caliper (hence the dumbass comment). I immediately realize that I probably just effed up my rear brake and will probably need a bleed (at the very least). After a pointless trip to the tire shop (different story), I decide to put the old tires back on. Surprisingly, the rear brakes slip right on, and work as before. My questions are: I thought that once depressed, I was under the impression that the caliper would need disassembly, repair and rebleeding (according to Clymer); however, it would seem that isn't the case. Am I overlooking something? Is Clymer wrong about this? Are my rear brakes gonna be safe? Link to comment
Ken H. Posted May 7, 2006 Share Posted May 7, 2006 As long as you didn't actually eject a piston, and you would know if you had as it would have puked brake fluid all over everywhere; no harm, no foul. Link to comment
RT Pilot Posted May 7, 2006 Author Share Posted May 7, 2006 Cool. ..thanks for the info Ken! Link to comment
mikewarax Posted May 7, 2006 Share Posted May 7, 2006 If the key wasn't on at the time you don't have anything to worry about. Servo brakes Mike Link to comment
RT Pilot Posted May 7, 2006 Author Share Posted May 7, 2006 yeah. . I know about the servo brakes, but they'd oughta work with the engine off, albeit a little harder, but they'd oughta work, right? That's why I was so (pleasantly) surprised that I hadn't effed up the brakes. . .thought that any pressure, whether servo assisted or not would eject the pistons. Anyway, I'm glad it turned out the way it did. . .now I gotta take the wheels off again, and I'll be a little wiser! Thanks! Link to comment
Rinkydink Posted May 8, 2006 Share Posted May 8, 2006 Go to a empty parking lot (leave plenty of room to stop) and turn off your key while you are still rolling in neutral and then use your brakes to stop. You will see how important the servo is I promise. Link to comment
Win3855 Posted May 8, 2006 Share Posted May 8, 2006 You could use a little slice of wood to slip in between the pads,just in case. Link to comment
