Claudio Posted July 31, 2020 Share Posted July 31, 2020 You can connect an aux power port (aka powerlet port). My RT had a stock port attached to it I believe. Useful for powering an air pump or anything you use short term/intermittently when the bike is off. Link to comment
jeffyjeff Posted July 31, 2020 Share Posted July 31, 2020 9 hours ago, Claudio said: You can connect an aux power port (aka powerlet port). My RT had a stock port attached to it I believe. Useful for powering an air pump or anything you use short term/intermittently when the bike is off. I also use it with my battery tender. Eliminates redundant unswitched connectors, and works well in that application. Link to comment
Miguel! Posted July 31, 2020 Author Share Posted July 31, 2020 Where'd you get the mating connector Jeffyjeff? Thanks. Miguel Link to comment
dirtrider Posted July 31, 2020 Share Posted July 31, 2020 1 hour ago, Miguel! said: Where'd you get the mating connector Jeffyjeff? Thanks. Miguel Afternoon Miguel They are usually all over E-Bay, just make sure you get (verify) that it is large round pin 1100/1150 socket & not the later 1200 small pin socket. https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=bmw+1100+power+socket&_sacat=0 Link to comment
Paul De Posted July 31, 2020 Share Posted July 31, 2020 It has been so long since I bought it for my R1100RT, but I believe this was a BMW OEM dual socket kit that plugged into that lead. It was bolt on plug & play accessory. I use one of the sockets with my heated vest as it keeps the wires out of the way from the handle bars. These days I suspect you'll have to keep an eye on Ebay for a used one to come up. Link to comment
jeffyjeff Posted August 2, 2020 Share Posted August 2, 2020 I personally purchased mine off Amazon. Just type in "powerlet" in the search box and click search. I hard wired a powerlet plug to a micro air pump, which I keep in a rolled towel in the tank cavity over the air filter. I keep a tire plug kit with the tools, so I'm ready for a flat on the road. Only took one time for me to realize those CO2 cartridges are dangerous and ineffective. Link to comment
MarinPhil Posted August 7, 2020 Share Posted August 7, 2020 On 7/31/2020 at 11:56 AM, Paul De said: It has been so long since I bought it for my R1100RT, but I believe this was a BMW OEM dual socket kit that plugged into that lead. It was bolt on plug & play accessory. I use one of the sockets with my heated vest as it keeps the wires out of the way from the handle bars. These days I suspect you'll have to keep an eye on Ebay for a used one to come up. Thats the aux sockets on my bike. Used for heated gear, no issues for full sleeve vest and gloves. I use the socket on the top left bank of switches left of the 3 toggle switches for battery monitor. Link to comment
Miguel! Posted August 7, 2020 Author Share Posted August 7, 2020 Thanks MarinPhil. I've been looking at battery monitors with USB connectors to plug into the dashboard connector above the switches as you have. I use my iPhone as a GPS which runs the battery down so having a USB connector in the cockpit is quite convenient and useful. Then I discovered that most USB adapters included a battery monitors with the USB adaptors. Clever. Currently I don't use that dashboard connectors so thought it'd be a a useful addition. Phil, Do I remember you have the same bike I do (R1100RT) with the same paint (Opal Blue)? Miguel Link to comment
MarinPhil Posted August 24, 2020 Share Posted August 24, 2020 On 8/6/2020 at 10:18 PM, Miguel! said: Thanks MarinPhil. I've been looking at battery monitors with USB connectors to plug into the dashboard connector above the switches as you have. I use my iPhone as a GPS which runs the battery down so having a USB connector in the cockpit is quite convenient and useful. Then I discovered that most USB adapters included a battery monitors with the USB adaptors. Clever. Currently I don't use that dashboard connectors so thought it'd be a a useful addition. Phil, Do I remember you have the same bike I do (R1100RT) with the same paint (Opal Blue)? Miguel Sorry, havent seen your post and been gone a while. Yes, we do have the same bike and she is doing just fine. This is a pic of the wire i use for up top battery monitor. SAE on one side to battery monitor ( Cetek or whatever you use) and DIN to bike. I case you have to make your own wire, SAE wire- red stripe is +, and on DIN plug, the wire that goes to the center is+. Or you can just buy one on amazon. Link to comment
Miguel! Posted August 25, 2020 Author Share Posted August 25, 2020 Thanks Phil. Cheers. Miguel Link to comment
