Shelterwoods Posted July 25, 2020 Share Posted July 25, 2020 I have an R1250RS with the GPS mount above the handle bar. I would like to remove the GPS mount and replace it with a mount for my phone. I can see two connectors that appear to attach to the wires from the mount. I would like to know if anyone has removed their mount and/or if removing it would cause any electrical issues. Thank you in advance for any insight. Del Link to comment
Claudio Posted July 25, 2020 Share Posted July 25, 2020 Hi Del, As the mount and power is auxiliary, it should not cause any electrical issues if removed. If you no longer need the power, I would recommend following the power harness to its source. It likely plugs in to a socket/adapter on the main wiring harness of the bike. Link to comment
Shelterwoods Posted July 25, 2020 Author Share Posted July 25, 2020 I've found two plugs that connect to it. I'll give it a try. Link to comment
