Rapala 50 Posted July 20, 2020 Share Posted July 20, 2020 I just purchased a used 4 button cradle Garmin gps base with two plugs and can't seam to located what I believe is the data cable on the bike which is a 2008 RT, I found the power plug located just above the right fork ( taped to some other wires ) but no luck on the other plug. Anyone here have an idea on where it is located and do I really need it ? Link to comment
dirtrider Posted July 20, 2020 Share Posted July 20, 2020 10 hours ago, Rapala 50 said: I just purchased a used 4 button cradle Garmin gps base with two plugs and can't seam to located what I believe is the data cable on the bike which is a 2008 RT, I found the power plug located just above the right fork ( taped to some other wires ) but no luck on the other plug. Anyone here have an idea on where it is located and do I really need it ? Morning Rapala 50 Does you 1200RT have a factory radio? Link to comment
Rapala 50 Posted July 20, 2020 Author Share Posted July 20, 2020 No it does not ..... Link to comment
dirtrider Posted July 20, 2020 Share Posted July 20, 2020 12 minutes ago, Rapala 50 said: No it does not ..... Afternoon Rapala 50 Then you have nothing on the motorcycle that needs a data connection as you have no radio or control on the handlebars. Link to comment
Rapala 50 Posted July 20, 2020 Author Share Posted July 20, 2020 Thanks DR, kind of what I was thinking but didn't want to put everything back together to find out other wise .... Link to comment
