greenrider Posted June 24, 2020 Share Posted June 24, 2020 I can change from sport, normal, to comfort. But I can't change the suspension. It's on the center stand,key on but nothing shows in the instrument panel when I push the button. GS911 shows a fault code I can't erase. And I can't calibrate because of some signal missing. Any help is appreciated Fault Codes : 1 | 41795 : Error in Calibration data for ESA Currently present : YES Symptom : Implausible signal or value Engine warning light (MIL) : NO Frequency count : 1 Logistic(Healing) count : 40 Fault Code History : Unknown Link to comment
dirtrider Posted June 24, 2020 Share Posted June 24, 2020 17 hours ago, greenrider said: I can change from sport, normal, to comfort. But I can't change the suspension. It's on the center stand,key on but nothing shows in the instrument panel when I push the button. GS911 shows a fault code I can't erase. And I can't calibrate because of some signal missing. Any help is appreciated Fault Codes : 1 | 41795 : Error in Calibration data for ESA Currently present : YES Symptom : Implausible signal or value Engine warning light (MIL) : NO Frequency count : 1 Logistic(Healing) count : 40 Fault Code History : Unknown Morning greenrider You probably have a calibration error or an ESA issue but is your engine running? Manual says it needs to be for suspension height adjustment. Also, if on the center stand then make sure the rear wheel isn't turning (sometimes will turn slowly in neutral)--- ESA susp height won't work if vehicle is moving. (a spinning rear wheel might make the system think that you are moving) Link to comment
greenrider Posted June 25, 2020 Author Share Posted June 25, 2020 I had the motor running and made sure the wheel wasn't turning. When I try to calibrate it says- Invalid response was obtained from vehicle. Link to comment
dirtrider Posted June 25, 2020 Share Posted June 25, 2020 10 hours ago, greenrider said: I had the motor running and made sure the wheel wasn't turning. When I try to calibrate it says- Invalid response was obtained from vehicle. Morning greenrider Not exactly sure what to tell you. It might just be a stuck or frozen up rear adjuster that won't move therefore no position movement feedback. I just looked for service bulletins on your rear strut & couldn't find anything (but I don't have access to all the available service bulletins for your bike). On the 1200 hexhead I could usually free up a stuck rear strut adjuster by spraying in penetrating oil on the adjuster ring & moving parts then powering it up directly from the battery in both up & down direction. Once I got it moving it would then move on it's own from the main control. I haven't had to address a CamHead (ESA II) rear strut yet so I really can't advise on how to do that (I would need a CamHead handy to figure it out. You might swing by your BMW dealer to see if they have had any similar issues on the CamHead, & if so, how they handled the problem. Or if in no hurry then maybe try spraying in some penetrating oil on the rear strut adjuster moving parts (not into the actuator) just the external spring seat movable area. Then ride the motorcycle & keep trying the adjustment. (or use you GS-911 to try to calibrate it). It might need a battery disconnect for while to get a rear strut calibration re-set. Link to comment
greenrider Posted June 26, 2020 Author Share Posted June 26, 2020 Disconnecting the battery didn't work. Being it can read code because there is a single missing. Could it be discontinued somewhere? Or would a broken wire give that message. I'm just thinking if wiring is all in tack why would it say signal missing if it is frozen. Just thinking out loud Link to comment
dirtrider Posted June 26, 2020 Share Posted June 26, 2020 17 minutes ago, greenrider said: Disconnecting the battery didn't work. Being it can read code because there is a single missing. Could it be discontinued somewhere? Or would a broken wire give that message. I'm just thinking if wiring is all in tack why would it say signal missing if it is frozen. Just thinking out loud Evening greenrider That no-signal could go either way. It could be an open circuit but it could also indicate no movement feed back received. I might be that it requests XX amount of movement but the strut spring seat doesn't move so it doesn't see the proper distance movement feedback from the strut. Link to comment
greenrider Posted July 10, 2020 Author Share Posted July 10, 2020 I have verified that the shock still works. The BMW dealer was kind enough to tell me which wires to energize and I was able cycle it in and out. But I still have the same problem. Can't calibrate or delete the fault. Link to comment
dirtrider Posted July 13, 2020 Share Posted July 13, 2020 On 7/10/2020 at 1:00 PM, greenrider said: I have verified that the shock still works. The BMW dealer was kind enough to tell me which wires to energize and I was able cycle it in and out. But I still have the same problem. Can't calibrate or delete the fault. Morning greenrider I'm not sure what you are dealing with on this. It might be the strut position sensor isn't outputting any, or not outputting correct, info on strut position, or the strut is working OK but the info isn't getting to the correct module, or it is somehow locked out & your GS-911 can't clear it. I'm kind of at a loss on what your next move should be. Maybe try posting your problem on the HexCode forum to see if anyone has any ideas. https://www.hexcode.co.za/ Link to comment
lather Posted July 25, 2020 Share Posted July 25, 2020 I have a new to me 2013 R!200RT and the ESA is not working. I can get the display to cycle from sport to normal and comfort and the load indicators as well but the suspension does not change. It seems to be stuck in sport. I do not have a GS911 so no info about codes. I see dirt rider suggested trying to get it unstuck " by spraying in penetrating oil on the adjuster ring & moving parts then powering it up directly from the battery in both up & down direction". I would like to try this but don't know which wires and where to find them. Can you help me with that greenrider? Link to comment
dirtrider Posted July 25, 2020 Share Posted July 25, 2020 16 hours ago, lather said: I have a new to me 2013 R!200RT and the ESA is not working. I can get the display to cycle from sport to normal and comfort and the load indicators as well but the suspension does not change. It seems to be stuck in sport. I do not have a GS911 so no info about codes. I see dirt rider suggested trying to get it unstuck " by spraying in penetrating oil on the adjuster ring & moving parts then powering it up directly from the battery in both up & down direction". I would like to try this but don't know which wires and where to find them. Can you help me with that greenrider? Evening lather Sport, normal, and comfort are damping settings not the spring pre-load (load setting). The preload (load setting) is shown as 1 helmet, 1 helmet+1suitcase, or 2 helmets. (this setting moves the spring seat) Your spring seat won't move during the sport, normal, and comfort setting changes. Look in your riders manual for how the suspension settings work & are adjusted. (look around pages 65 & 66) Link to comment
6speedTi Posted July 26, 2020 Share Posted July 26, 2020 I remember when I first played around with the settings on my 2012rt while I was riding on the highway with an occasional dip and bump in the road I could feel a subtle difference in rebounding. Sport was stiffer and comfort did bounce a bit more but all in all the settings were not drastic. With 1 up or 2 up it I hardly noticed a change. So settings are minimal in ride and feel. You do notice a difference. I don't normally ride 2 up so I'm guessing it will change your rebounding affect as well. Link to comment
lather Posted July 26, 2020 Share Posted July 26, 2020 Thanks, I was a bit confused. I will study the manual and try again. Link to comment
lather Posted July 28, 2020 Share Posted July 28, 2020 Ok, after reading the instructions again I have verified the preload adjustment was working. I was not waiting long enough. And after a two day 400 mile trip the the damping seems satisfactory except on real big bumps in the road. A bit harsher than my Concours 14 which has Ohlins. Link to comment
pwillikers Posted May 30, 2023 Share Posted May 30, 2023 Which wires do you energize (with 12V?) (in the electrical connector closest to the shock) to validate that preload is actually changing on an ESA II rear shock? Which wires do you energize (with 12V?) (in the electrical connector closest to the shock) to validate that damping is actually changing on both an ESA II front and rear shock? Thanks. Link to comment
greenrider Posted June 6, 2023 Author Share Posted June 6, 2023 Below is what he had told me. I assume you have the mechanical aptitude to work through this.You will need to locate the wires that go to the motor part of the ESA. Pull the connectors apart and locate the blue/gray and blue/yellow wires. They should be larger than the other wires going to the ESA. Using a couple jumper wires from the battery, connect one of those ESA wires to positive and touch the ground to the other wire. You will get a spark but you should hear the motor running. Now reverse the wires and bump it in the other direction Link to comment
greenrider Posted June 15, 2023 Author Share Posted June 15, 2023 Because it's an expensive part to get it to work I connected two wires to the plug and when I need the suspension changed from traveling with my wife to commuting to work I lift the seat and touch the wires to battery. It needs to be quite so I can hear motor and hear when its at its limit. Link to comment
pwillikers Posted June 30, 2023 Share Posted June 30, 2023 Thanks Greenrider for the info on the ESA wiring. Link to comment
