jjpen Posted June 14, 2020 Share Posted June 14, 2020 I just put a new clutch switch on my 2010rt and now it still will not start in gear. I also have a new problem that the cruise won't engage. Does anyone think or know if I might have the new switch installed upside down? Link to comment
Mark Cross Posted June 14, 2020 Share Posted June 14, 2020 I have 3 rt's and they won't start in gear. Neutral only. 2008 Link to comment
jjpen Posted June 14, 2020 Author Share Posted June 14, 2020 My rt's have always started in gear until the clutch switch fails. Link to comment
dirtrider Posted June 14, 2020 Share Posted June 14, 2020 17 hours ago, jjpen said: I just put a new clutch switch on my 2010rt and now it still will not start in gear. I also have a new problem that the cruise won't engage. Does anyone think or know if I might have the new switch installed upside down? Morning jjpen I'm not sure that is possible but I suppose it could be. Look on your old (removed) switch to see if the screw witness marks can tell you anything about how it was installed, then see if your new switch is installed the same way. Otherwise you might use an ohmmeter to see if the new switch is working as you move the clutch lever. Link to comment
jjpen Posted June 14, 2020 Author Share Posted June 14, 2020 well I had fifty per cent chance of installing that switch correctly. Guess what happened when I turned it upside down. I have cruise control and start in gear!!! Thanks for the input. Link to comment
Ponch Posted June 15, 2020 Share Posted June 15, 2020 Funny, mine is starting to act up. If I pump the clutch, it will catch. There is a dead spot in the switch. Link to comment
