David13 Posted June 3, 2020 Share Posted June 3, 2020 I'm installing the new tire pressure monitor sensors. The Hexcode GS911 worked perfectly at learning the new sensors as Set B. The EL 50448 device woke the sensors up when the GS 911 asked for that. The question now is will the bike just use Set B or does the bike have to be told to do that? dc Link to comment
TestPilot Posted June 3, 2020 Share Posted June 3, 2020 The bike will detect whichever sensors are installed. If you don't plan to keep the old sensors you can use the GS-911 to delete Set A. Or you can keep them as spares (with new batteries if that's why you replaced them) and when you put them back in no additional work will be necessary. Link to comment
