jjpen Posted May 22, 2020 Share Posted May 22, 2020 when i had a 09 i put it behind the mirror. where in the world can i put it to not need another key? Link to comment
Dann Posted May 23, 2020 Share Posted May 23, 2020 Had the same issue when I bought my 2019 rt . I use this box to hold the key and stick it somewhere on the bike It's magnetic and there is also a metal plate that you can stick anywhere you want for the magnet to work YMMV Link to comment
jjpen Posted May 24, 2020 Author Share Posted May 24, 2020 how about a name and source for that box? And thank you, Link to comment
szurszewski Posted May 24, 2020 Share Posted May 24, 2020 I think that’s the Kidde Stor-a-Key and it’s about $10 from lots of places online. Link to comment
jjpen Posted May 30, 2020 Author Share Posted May 30, 2020 If anyone else is interested, my solution was to gently remove the cover where the audio controls would be located on a bike with a radio, which my bike does not have, and zip tie the key and let it hang. Some of the material between the holes must be removed for the key to have room to pass through. My bike had already had the material removed to mount a Clearwater dimmer control. I can hook my fingernails under the cover and remove it without any tools to give me access to the key. 1 Link to comment
