Iron Al Posted May 2, 2006 Share Posted May 2, 2006 Just wondering what everyone's preference is in rain suites. Do you like the one piece or two peice rain suit? If you like, please post why. Link to comment
kdude Posted May 2, 2006 Share Posted May 2, 2006 I'm using the BMW one piece suit... its a cinch to put on and it keeps me dry. Link to comment
PhotoBiker Posted May 2, 2006 Share Posted May 2, 2006 I have the Aerostich Roadcrafter Suit, how do I vote for this?? Before this, however, I had a 2 piece "Stuff it in the saddle bag" suit. It made more sense as the jacket top could double as a windbreaker once destinated... Link to comment
GordonB Posted May 3, 2006 Share Posted May 3, 2006 BMW 2pc. Many times on the RT I only need the top, Hvy misting, cold, dreary kinda days. Link to comment
Albert Posted May 3, 2006 Share Posted May 3, 2006 I've always preferred the 2 piece. There are times in a light rain when the protection from the bike is enough to cover my legs and I only wear the jacket for upper body. This is especially true in hotter weather. On the flip side, again in hotter conditions, it's easier to yank off the jacket at a gas/rest stop without having to remove the pants. Since my real love is touring I have always considered a good rain suit an absolute essential. Staying dry, and often warm, can make all the difference on a trip. I currently have a HD 2 piece which is (please no brand wars here) a high quality product. I have ridden in conditions where scuba gear could have been used and have remained dry. The only recommendation I'll make regarding fit, is make sure the leg portion (1 or 2 piece) has a long opening capacity (preferably all the way to the hip). A problem donning the pants can find you rolling around on the soaked shoulder of the interstate using language that would make a drunken sailor blush. Link to comment
Aluminum_Butt Posted May 3, 2006 Share Posted May 3, 2006 [slight Hijack] I also have the BMW one-piece. In prolonged, heavy rain, though, I have a heck of a time with water collecting at the bottom of the zipper, where it ultimately leaks into the suit and onto my crotch. Anybody have the same issue and/or a fix? [End Hijack] Link to comment
Aluminum_Butt Posted May 3, 2006 Share Posted May 3, 2006 A problem donning the pants can find you rolling around on the soaked shoulder of the interstate using language that would make a drunken sailor blush Tip of the day - carry a plastic shopping bag with you. When you put your rain suit on, slip the bag over your boot before you step into the suit. Really helps. Link to comment
Albert Posted May 3, 2006 Share Posted May 3, 2006 The plastic is an excellent point. I used to use a pair of Totes as boot covers. If you could find the boot size they really weren't bad, but they were REALLY hard to slip over wet boots. I took to covering my boots in gallon size zip locks before slipping on the Totes and it was slicker than, well you get the idea. By the way, I've heard similar complaints from other one piece users although it wasn't with the BMW suit. Link to comment
Ralph Posted May 4, 2006 Share Posted May 4, 2006 Harley Gortex rain suit here. Never got wet yet! Link to comment
Rags Posted May 4, 2006 Share Posted May 4, 2006 [slight Hijack] I also have the BMW one-piece. In prolonged, heavy rain, though, I have a heck of a time with water collecting at the bottom of the zipper, where it ultimately leaks into the suit and onto my crotch. Anybody have the same issue and/or a fix? [End Hijack] My BMW 1 pc has a crotch pocket that can collect water from the bottom of the zipper. Of course I don't know what happens when it over flows (or maybe I do) Link to comment
JerryMather Posted May 6, 2006 Share Posted May 6, 2006 I've been using a Hein Gericke, Speedware 2 piece one for a few years now and haven't gotten wet yet. The two piece ones seem to me to be less of a hasssel to have on. Link to comment
Scarecrow Posted May 21, 2006 Share Posted May 21, 2006 A problem donning the pants can find you rolling around on the soaked shoulder of the interstate using language that would make a drunken sailor blush Tip of the day - carry a plastic shopping bag with you. When you put your rain suit on, slip the bag over your boot before you step into the suit. Really helps. I used this tip the other day and wondered why I never thought of something so easy myself. It worked Great! Thanks for passing that tip on. Link to comment
pipenslippers Posted May 22, 2006 Share Posted May 22, 2006 We both use BMW 2 piece. The only leak was where the top and bottom join, but now I do a "roll" joint between the trousers top and the jacket bottom. I could probably swim in it now and stay dry. Link to comment
SWB Posted May 24, 2006 Share Posted May 24, 2006 I'm still in the "evaluation stage" as I piece together touring gear. I've heard many swear by Frogg Toggs (2 piece). I'm told that the up side is that they are light, store compactly, and breath well. Down side is that they aren't heat proof, and will melt if they contact the exhaust system. Most come in camo colors, but there is one orange version which looks fairly visable. I'm about to order them here. Any comments about the product, pro or con? I still wear my old leather, steel toed Navy boots for riding, and may look for some conventional rubber overshoes to improve the water resistance. (Or, by the time I need really them, I may have dropped the cash for a set of all-weather motorcycle boots.) Link to comment
Yankee_Dog Posted May 24, 2006 Share Posted May 24, 2006 I use the Frogg Toggs. You have the pro and con just about right. IIRC for an extra charge you can get them with a heat shield on the inside of your leg. Check out the factory website. www.froggtoggs.com Yankee Dog Link to comment
