Budgie UK Posted May 9, 2020 Share Posted May 9, 2020 I own a Grinnall Scorpion 3 which is powered by a BMW K1300s (2010) engine. Came around for MOT last week and I went to start the motor it was spinning the engine rapidly soci don't think it's a battery issue but it wouldn't start. After several attempts it fired up but it sounded rattley for a few seconds and soon settled down. I drove to the test station and it was fine. All the power was there and it ran beautifully. At the test station it did it again. Could this be a Crankshaft sensor problem? Link to comment
dirtrider Posted May 9, 2020 Share Posted May 9, 2020 1 hour ago, Budgie UK said: I own a Grinnall Scorpion 3 which is powered by a BMW K1300s (2010) engine. Came around for MOT last week and I went to start the motor it was spinning the engine rapidly soci don't think it's a battery issue but it wouldn't start. After several attempts it fired up but it sounded rattley for a few seconds and soon settled down. I drove to the test station and it was fine. All the power was there and it ran beautifully. At the test station it did it again. Could this be a Crankshaft sensor problem? Morning Budgie UK Sure it COULD be a Crankshaft sensor problem? But it could also be many other things, even water in the petrol. Link to comment
Budgie UK Posted May 9, 2020 Author Share Posted May 9, 2020 Scorpion is stored in a garage when not used. Wondering if my gs911 tester will highlight the problem? Link to comment
dirtrider Posted May 9, 2020 Share Posted May 9, 2020 7 minutes ago, Budgie UK said: Scorpion is stored in a garage when not used. Wondering if my gs911 tester will highlight the problem? Afternoon Budgie UK Where it was stored might not make much difference if added fuel with water in it at a petrol station. Yes, put your GS-911 on it to see if you have any stored failure codes. (might point to something) Link to comment
Budgie UK Posted May 9, 2020 Author Share Posted May 9, 2020 I'll try it tomorrow and let you know the results. Thanks for the advice. Link to comment
Budgie UK Posted May 20, 2020 Author Share Posted May 20, 2020 Finally found my tester. Car kept failing to start when it went for MOT. The man at the garage said it sounded like the Crankshaft sensor was faulty. But no fault came up when gs911 was plugged in. So heck knows what the problem was?? Link to comment
wmeacham Posted October 8, 2020 Share Posted October 8, 2020 When you push the starter you here the starter motor? There is a clutch that engages the motor it may be gummed up. Try changing the oil. Add some seaform(engine declogger) to the oil prior to the change run it for 30 min or so then drop the oil and filter then replace both. Link to comment
