Skywagon Posted April 28, 2020 Share Posted April 28, 2020 I am having a bit of an issue with my left hand mirror. It's never been hit, never fallen over, or any damage. Due to tight parking in the garage I fold in the mirrors on the bike. Recently the left mirror won't stay folded it pops right back to riding position. I took the cover off and see it has a spring and bolt that could be tightened. I tightened it a bit but no change in results. Any suggestions? Link to comment
Dann Posted April 28, 2020 Share Posted April 28, 2020 I think it's made to fold back in position and not stay folded. Link to comment
Skywagon Posted April 28, 2020 Author Share Posted April 28, 2020 After some more fiddling around with it I figured it out. Instead of tightening the nut over the spring...loosening it solved the problem. I guess it tightened up after many times of folding it in. Dann...not sure but on all my BMW bikes when I fold them in they stay put. This one did too until recently. Now it does again. Link to comment
Dann Posted May 1, 2020 Share Posted May 1, 2020 Maybe I should try on mine and see what it does Link to comment
alexp Posted May 2, 2020 Share Posted May 2, 2020 Yes is designed to fold in in case you hit something. I end up in adding a small steel cable to the mirror in case it falls off, it will stays with the bike. Link to comment
Dann Posted May 3, 2020 Share Posted May 3, 2020 My r1250Rt mirrors came attached with cables attached to them Link to comment
