Sign in to follow this
vhntr1
05 RT throttle cam success
vhntr1
A big thank you to Dirtrider for his great instructions and answers to all my questions,replaced the cams tonight as per his information all went smoothly,the cams had much larger cracks on the inside of the cams that could not be seen.Put it all back together did  a tps  reset  and synced the throttle body's ,it runs much better now then it has for the last 5 k
Thank again DR
Share this post
Link to post
dirtrider
10 hours ago, vhntr1 said:
A big thank you to Dirtrider for his great instructions and answers to all my questions, replaced the cams tonight as per his information all went smoothly, the cams had much larger cracks on the inside of the cams that could not be seen. Put it all back together did  a tps  reset  and synced the throttle body's, it runs much better now then it has for the last 5 k
Thank again DR
Morning vhntr1
You are welcome, glad it worked out OK for you.
I have been getting a few reports back that the Throttle Cam Replacement procedure is working.
---1200 hexhead 'Throttle Body Cam' replacement procedure,  click link  below ____
   https://www.bmwsporttouring.com/topic/92006-posted-to-see-how-a-tb-shaft-install-how-to-reads-in-a-full-thread/
Share this post
Link to post
