The Rocketman Posted April 17, 2020 Share Posted April 17, 2020 Please confirm that the front axle bushing/spacer goes with the recessed groove (red arrow) facing the wheel bearing, and the non-grooved end faces the inside of the fork leg. Thanks! Link to comment
dirtrider Posted April 17, 2020 Share Posted April 17, 2020 40 minutes ago, The Rocketman said: Please confirm that the front axle bushing/spacer goes with the recessed groove (red arrow) facing the wheel bearing, and the non-grooved end faces the inside of the fork leg. Thanks! Afternoon Rocketman Actually it probably goes in the trash pile. That looks like grease seal wear into the bushing surface. You might at least turn it around. Put a little grease on the bushing & in the seal lips so it doesn't wear again. Link to comment
The Rocketman Posted April 17, 2020 Author Share Posted April 17, 2020 I didn't know what a new one looked like so thanks for the head's up. I will reverse it and grease it as you say. Regular pink-ish wheel bearing grease OK? Link to comment
dirtrider Posted April 17, 2020 Share Posted April 17, 2020 6 minutes ago, The Rocketman said: I didn't know what a new one looked like so thanks for the head's up. I will reverse it and grease it as you say. Regular pink-ish wheel bearing grease OK? Evening Rocketman Yes, that will be fine. Put a thin coat of grease on the full length of the axle also as that prevents corrosion & makes removal in the future easier. Link to comment
The Rocketman Posted April 17, 2020 Author Share Posted April 17, 2020 On it! Thanks again. Link to comment
dirtrider Posted April 17, 2020 Share Posted April 17, 2020 9 minutes ago, The Rocketman said: On it! Thanks again. Evening Rocketman Next tire change you might want to think about installing as new seal. Link to comment
