Warren Dean Posted April 10, 2020 Share Posted April 10, 2020 So, I wear cowboy boots instead of the more traditional MX style boots for riding my Beemer. AND I wear a lighter color than black.... That said, has anyone found a commercially available product to keep the shifter from leaving black and silver deposits on the top of my left boot? I am not worried about wear.....it just looks tacky since I ride to, and wear these boots at, work. I have thought of heat shrink tubing over the shifter rubber but thought I would see if the brain trust here has a better idea. Cheers! Warren Link to comment
Skywagon Posted April 10, 2020 Share Posted April 10, 2020 Ive never used any but here is a couple of ideas. https://www.revzilla.com/motorcycle/nelson-rigg-shift-boot-protector?gclid=EAIaIQobChMIgYDS-evc6AIVhJyzCh3P6AdjEAQYASABEgJU3PD_BwE https://www.amazon.com/KEMANI-Universal-Shifter-Protector-Motorcycle/dp/B06XWY1MLH Link to comment
Rinkydink Posted April 10, 2020 Share Posted April 10, 2020 Believe it or not I’ve used scotch tape. 1 Link to comment
szurszewski Posted April 10, 2020 Share Posted April 10, 2020 I’ve had good luck with one like the Amazon link above. Cheap and easy to install, and you don’t have to mess with something each ride (like the boot cover also linked above). I think I picked it up at my local cycle gear for about seven bucks. Link to comment
Miguel! Posted April 10, 2020 Share Posted April 10, 2020 I installed a Hornig shifter extender primarily to distribute the shifter pressure across more than big toe. They are aluminum. I don't think they will leave black marks but regardless of what you use, it will likely make that part of your lighter-colored boot a bit dirtier than other parts. ~$30. It fits over the OEM shifter so its is a bit larger diameter and longer. I got mine at Sierra BMW. Comes with or without o-rings Best Miguel 1 Link to comment
Warren Dean Posted April 10, 2020 Author Share Posted April 10, 2020 9 hours ago, szurszewski said: I’ve had good luck with one like the Amazon link above. Cheap and easy to install, and you don’t have to mess with something each ride (like the boot cover also linked above). I think I picked it up at my local cycle gear for about seven bucks. I will probably go that route. Cheap and easy are good. :) Link to comment
Rinkydink Posted April 10, 2020 Share Posted April 10, 2020 11 hours ago, Hosstage said: Fit a heel shifter? If you installed a heel shifter on your BMW you’re on your own...😬 1 Link to comment
szurszewski Posted April 10, 2020 Share Posted April 10, 2020 59 minutes ago, Rinkydink said: If you installed a heel shifter on your BMW you’re on your own...😬 Nah... Link to comment
Warren Dean Posted April 10, 2020 Author Share Posted April 10, 2020 I wonder if someone makes or made one for oilheads? That's pretty interesting... Link to comment
Rinkydink Posted April 10, 2020 Share Posted April 10, 2020 34 minutes ago, szurszewski said: Nah... Wow, you learn something new every day. I’ve never seen that. Link to comment
szurszewski Posted April 10, 2020 Share Posted April 10, 2020 I’ve not see one on an oilhead - airheads and K1200LTs I’ve seen in person, and the internet search that yielded this pics found some on K16s. I bet someone out there has done it - doesn’t seem like it would be too hard. I’ve only ridden a bit with them - mostly on some various sidecars others were kind enough to let me try - and I defiantly am not proficient with them. Link to comment
Skywagon Posted April 10, 2020 Share Posted April 10, 2020 My 1979 R100RT had one. I never used the heel part. Link to comment
Hosstage Posted April 10, 2020 Share Posted April 10, 2020 That's funny! I was just joking, but it turns out I knew what I was talking about! That probably won't happen again. 2 Link to comment
Warren Dean Posted April 10, 2020 Author Share Posted April 10, 2020 1 hour ago, Skywagon said: My 1979 R100RT had one. I never used the heel part. That is a gorgeous machine!! 1 Link to comment
The Fabricator Posted April 10, 2020 Share Posted April 10, 2020 I have tinkered with my unit a little. This is my heel-toe set up. I recommend h-t. Link to comment
Warren Dean Posted April 13, 2020 Author Share Posted April 13, 2020 On 4/10/2020 at 12:34 PM, The Fabricator said: I have tinkered with my unit a little. This is my heel-toe set up. I recommend h-t. I've been to 2 county fairs and a goat ropin' and I ain't never seen anything like that.... 1 Link to comment
The Fabricator Posted April 13, 2020 Share Posted April 13, 2020 16 hours ago, Warren Dean said: I've been to 2 county fairs and a goat ropin' and I ain't never seen anything like that.... Never occurred to me to enter the bike into the county fair or the goat roapin' event. Thanks for the tip. 1 Link to comment
tallman Posted April 14, 2020 Share Posted April 14, 2020 Cowboy boots? What is the sole made of? To each, but I was not likely to ride without a non leather sole. Too slick in many conditions. Not to mention lack of protection. I kept shoes at work, tub under desk, and wore mc specific boots. Waterproof and protection. YMMV Link to comment
Warren Dean Posted April 14, 2020 Author Share Posted April 14, 2020 10 minutes ago, tallman said: Cowboy boots? What is the sole made of? To each, but I was not likely to ride without a non leather sole. Too slick in many conditions. Not to mention lack of protection. I kept shoes at work, tub under desk, and wore mc specific boots. Waterproof and protection. YMMV They have rubber soles. And I don't ride in the rain without slip-on rain boots. This ain't my first rodeo. Link to comment
Hosstage Posted April 14, 2020 Share Posted April 14, 2020 I just own the shifter mark on my boots, it happens because I ride. But then I don't work in an office. I don't even have nice boots now that I think about it... 1 1 Link to comment
Jim Moore Posted April 17, 2020 Share Posted April 17, 2020 I didn't like position of the the shifter on my R1100RS. It didn't stick out far enough, and I had to turn my foot inboard to shift. As I pondered how to fix it, I realized that all i really needed to do was slide a piece of metal pipe over it to make it a little longer. Since I was sitting in the garage on a pile of tools, I reached over and grabbed a long- each 3/4" socket. A few taps with the hammer and it slid right on. Presto! Instant shifter extension. Sounds like that would fix your problem too. 1 Link to comment
Warren Dean Posted April 17, 2020 Author Share Posted April 17, 2020 8 minutes ago, Jim Moore said: I didn't like position of the the shifter on my R1100RS. It didn't stick out far enough, and I had to turn my foot inboard to shift. As I pondered how to fix it, I realized that all i really needed to do was slide a piece of metal pipe over it to make it a little longer. Since I was sitting in the garage on a pile of tools, I reached over and grabbed a long- each 3/4" socket. A few taps with the hammer and it slid right on. Presto! Instant shifter extension. Sounds like that would fix your problem too. No doubt. I am currently using one of those plastic l shaped covers. We shall see how it lasts, but I like the idea of a metal extension that doesn't cost $50. 1 Link to comment
Miguel! Posted April 18, 2020 Share Posted April 18, 2020 That was a clever idea Jim Moore. Best Miguel Link to comment
Rinkydink Posted April 18, 2020 Share Posted April 18, 2020 14 hours ago, Jim Moore said: I didn't like position of the the shifter on my R1100RS. It didn't stick out far enough, and I had to turn my foot inboard to shift. As I pondered how to fix it, I realized that all i really needed to do was slide a piece of metal pipe over it to make it a little longer. Since I was sitting in the garage on a pile of tools, I reached over and grabbed a long- each 3/4" socket. A few taps with the hammer and it slid right on. Presto! Instant shifter extension. Sounds like that would fix your problem too. Wouldn’t a 19mm be more appropriate? 😜 1 Link to comment
Jim Moore Posted April 18, 2020 Share Posted April 18, 2020 2 hours ago, Rinkydink said: Wouldn’t a 19mm be more appropriate? 😜 LOL, yeah the 19 worked too. But I need that 19, so I started playing around with the SAE stuff I never use. 2 Link to comment
Rinkydink Posted April 18, 2020 Share Posted April 18, 2020 18 minutes ago, Jim Moore said: LOL, yeah the 19 worked too. But I need that 19, so I started playing around with the SAE stuff I never use. Ahh, smart move...that’s using your noggin. 1 Link to comment
