EDO Posted April 30, 2006 Share Posted April 30, 2006 Without the excruciating detail, I've got a set of PIAA 1100X's set up on my R1200RT and the wiring harness and the lights are connected with a nice soldered and wrapped connection - which is great until my next service when the side fairings will need to be removed and they will be tethered by this wire - because the EZ mount is connected to the fairing. Here's what I'm looking for - anyone know where I can find a nice marine grade waterprrof connection plug to attach to the 12 gauge wire so it can plug in nicely and then be unplugged for service (faring removal)? I tried radio shack and they have connectors - but they were fairly cheap and not waterproof - I tried my local marine store and they did not have "pluggable" connections. Thanks! Ed PS - If you are curious, I ended up with a set of powersports PIAA 1100X's and a "original" wire harness - same electrical set-up but PIAA changed the wiring harness connection on the Powersports version - I had to cut the non compatible plugs for my connection... Link to comment
Bobmws Posted April 30, 2006 Share Posted April 30, 2006 Use a standard SAE connector, like a trailer wiring plug, only 2 poles. Same type of plug Powerlet uses for their tank bag electrification kit. I've used them for years, no problem with water intrusion. They usually come as a 12" length with a connector in each end. I cut the length in half, and use 1/2 to go through the body of my Hella lights, putting connectors on that wire, eliminating the stock cnnectors. Then I splice the matching end of the plug onto the cut end of the wiring harness. Tip: Make sure you connect the positive lead on the harness feeding the light to the shrouded side of the SAE connector. Link to comment
bmwscoot Posted April 30, 2006 Share Posted April 30, 2006 You are probably looking for something like a Weather-Pak connector. Google that, and you are sure to find a local distributor. Here is a vendor that gives pin #'s with wire sizing. http://www.electerm.com/packard.html Many on-line vendors sell the connectors without telling you what the wire size rating is. Link to comment
