Warren Dean Posted March 27, 2020 Share Posted March 27, 2020 Has anyone ever done a definitive post on the proper locations for the 3 or 4 different screws that attach the Tupperware to an 1100RT? There are short pointy screws, short blunt screws, medium pointy screws, medium blunt screws...you see my point. I know where the long ones go but I would just like to make sure I have them in their proper positions. Cheers! Warren Link to comment
TEWKS Posted March 27, 2020 Share Posted March 27, 2020 This may HELP but, if not, maybe a better answer will show up. Hey Warren, you may need some of this...Just Sayin' Link to comment
Warren Dean Posted March 27, 2020 Author Share Posted March 27, 2020 27 minutes ago, TEWKS said: This may HELP but, if not, maybe a better answer will show up. Hey Warren, you may need some of this...Just Sayin' Bwahahaha!!! 1 Link to comment
Warren Dean Posted March 27, 2020 Author Share Posted March 27, 2020 Thanks.That helps. 👍👍 Link to comment
Warren Dean Posted March 27, 2020 Author Share Posted March 27, 2020 1 hour ago, PAS said: Perfect!! Thanks Cheers! Warren Link to comment
AndyS Posted March 27, 2020 Share Posted March 27, 2020 As stock, the 3 different length screws all had pointy ends. Any screws that don't have those screws with the points on are not from the fairing or (more likely) aftermarket items. If this is your first time doing this, take your time, leave everything loose until everything is lined up. DO NOT cross thread these screws. Don't overtighten them, they only need the lightest of nips. Link to comment
PAS Posted March 27, 2020 Share Posted March 27, 2020 Pointed end screws are a must to prevent cross threading! I would not recommend regular screws for this purpose. Link to comment
Warren Dean Posted March 27, 2020 Author Share Posted March 27, 2020 2 hours ago, AndyS said: As stock, the 3 different length screws all had pointy ends. Any screws that don't have those screws with the points on are not from the fairing or (more likely) aftermarket items. If this is your first time doing this, take your time, leave everything loose until everything is lined up. DO NOT cross thread these screws. Don't overtighten them, they only need the lightest of nips. No, not my first time and I was kind of curous as to why there would be pointy ones and blunt ones. I think I have it figured out now. Thanks. Cheers! Warren Link to comment
Miguel! Posted March 27, 2020 Share Posted March 27, 2020 Its tempting to get stainless steel screws rather than the aluminum screws, but the stainless are likely to strip the the threaded insert because they don't have a point to guide the screw in perpendicular to the insert. Miguel Link to comment
dirtrider Posted March 27, 2020 Share Posted March 27, 2020 1 hour ago, Warren Dean said: No, not my first time and I was kind of curous as to why there would be pointy ones and blunt ones. I think I have it figured out now. Thanks. Cheers! Warren Afternoon Warren Some end up with a couple of flat ended screws after removing the Tupperware & removing the fuel tank for service (even with the original factory screws). There are 2 screws in the front of the fuel tank that some remove thinking that they need removal for fuel tank removal. Those screws are there to attach tank bag mounting straps if a tank bag is later installed. On non-tank-bag bikes those screws are basically there to just plug the threaded holes. (no need to remove for tank removal) Those front tank screws (shown in picture below) should only be flat end, not pointed, as the screw holes are not very deep & the tank plastic isn't very thick under the screws. Link to comment
Warren Dean Posted March 27, 2020 Author Share Posted March 27, 2020 Glad to know how I will attach my new to me Marsee tank bag at the front. And I'll just leave the straps attached. Sweet!! Thanks for the info. Cheers! Warren Link to comment
Warren Dean Posted March 27, 2020 Author Share Posted March 27, 2020 1 hour ago, Miguel! said: Its tempting to get stainless steel screws rather than the aluminum screws, but the stainless are likely to strip the the threaded insert because they don't have a point to guide the screw in perpendicular to the insert. Miguel That's where 30+ years of messing with things mechanical and fasteners comes in handy...LOL I'll stick with what is there for now as it seems to work fine. Thanks. Cheers! Warren Link to comment
dirtrider Posted March 27, 2020 Share Posted March 27, 2020 22 minutes ago, Warren Dean said: Glad to know how I will attach my new to me Marsee tank bag at the front. And I'll just leave the straps attached. Sweet!! Thanks for the info. Cheers! Warren Evening Warren BMW used to offer special clips to go on the front of tank (on those screws mentioned in my post above) those allow the tank bag straps to clip on & off. I haven't seen those clips available in a long time now but you might find some on E-Bay, or pretty easy to make something similar to fit your tank bag strap hooks. (picture will give you some idea). Link to comment
ltljohn Posted March 27, 2020 Share Posted March 27, 2020 FWIW I made a drawing on cardboard and poked holes in it for each screw so I could put it back in the same hole it came out of. 1 Link to comment
Warren Dean Posted March 27, 2020 Author Share Posted March 27, 2020 39 minutes ago, ltljohn said: FWIW I made a drawing on cardboard and poked holes in it for each screw so I could put it back in the same hole it came out of. That is brilliant!!! I wish I had thought of it.... Link to comment
Warren Dean Posted March 27, 2020 Author Share Posted March 27, 2020 1 hour ago, dirtrider said: Evening Warren BMW used to offer special clips to go on the front of tank (on those screws mentioned in my post above) those allow the tank bag straps to clip on & off. I haven't seen those clips available in a long time now but you might find some on E-Bay, or pretty easy to make something similar to fit your tank bag strap hooks. (picture will give you some idea). I just got through doing it the redneck way...screws through the straps and let them hang there. It's the way my other 97 had been set up worked pretty well. I sure like the idea of the BMW ones, though. Link to comment
ltljohn Posted March 28, 2020 Share Posted March 28, 2020 20 minutes ago, Warren Dean said: That is brilliant!!! I wish I had thought of it.... I learned it here on the board 1 Link to comment
PAS Posted March 30, 2020 Share Posted March 30, 2020 I used the two front screws to attach my Marsee 12 liter tank bag. Bike is gone but like new tank bag isnt. Anyone looking for one? Link to comment
AviP Posted March 30, 2020 Share Posted March 30, 2020 I just throw all the 30-40 screws in a pile and just wing it. The beer eases the pain! 1 Link to comment
Warren Dean Posted March 31, 2020 Author Share Posted March 31, 2020 2 minutes ago, AviP said: I just throw all the 30-40 screws in a pile and just wing it. The beer eases the pain! Good plan!! Link to comment
