don_k Posted April 29, 2006 Share Posted April 29, 2006 In response to my previous post about an ABS problem I got a reply with instructions on reading the codes. At first I was trying to count the voltage drops with a digital multimeter. I couldn't get a good count and decided to just check the gaps on the sensors. They were off so I re-shimmed them figuring that must have been the problem but I still get complains from the ABS system. Yesterday I stopped on the way home from work and picked up an analog multimeter and now I can read the voltage drops with no problem. I get a code 7 which the cheat sheet says is the ABS unit. Anyone else have this problem? If so, what was the cure? Does it mean the whole unit or are there sub components I can check for failures in? Thanks Don Kramber Link to comment
ShovelStrokeEd Posted April 29, 2006 Share Posted April 29, 2006 When was the last time you did a brake fluid flush? It is simple to do on your bike and might just clear the code. Link to comment
don_k Posted April 30, 2006 Author Share Posted April 30, 2006 Full flush of the brake fluis was completed a week ago. Don Kramber Link to comment
