Bradey1 Posted April 29, 2006 Share Posted April 29, 2006 I purchased 05 RT last fall and have only 3500 miles on it. Recently noticed the oil "check" indicator does not appear until at least 6 miles into ride. The "---" indicator stays on longer than the manual indicates it should. I assume it is a faulty oil sensor, but am concerned about engine damage if it is something else. Any advice? Link to comment
bobiverson Posted April 29, 2006 Share Posted April 29, 2006 Sounds like normal operation to me -- no worries! BOB Link to comment
ChrisA Posted April 29, 2006 Share Posted April 29, 2006 You say 6 miles, but I'm guessing the warning light won't come on until the temperature is up to operating specs rather than a particular distance. Link to comment
Pickaxe Posted April 29, 2006 Share Posted April 29, 2006 I purchased 05 RT last fall and have only 3500 miles on it. Recently noticed the oil "check" indicator does not appear until at least 6 miles into ride. The "---" indicator stays on longer than the manual indicates it should. I assume it is a faulty oil sensor, but am concerned about engine damage if it is something else. Any advice? You haven't read the manual properly. Unless the bike is up to working temp, stationary and idling for a few seconds, the check isn't completed. It's quite possible that you could ride 250 miles (probably not on UK roads) without the check ever being made. Link to comment
