bulletbill Posted February 24, 2020 Share Posted February 24, 2020 MY LEFT REAR CASE HINGE HAS COME LOOSE? BOLTS ARE STILL THERE BUT WILL NOT TIGHTEN FROM THE OUT SIDE? HOW DO I GET TO THE NUTS(???) THE HINGLE IS LOOSE ON BOTH THE INNER CASE AND THE LID. Link to comment
The Rocketman Posted February 25, 2020 Share Posted February 25, 2020 DUPLICATE THREAD HERE: This link might help: I've had mine apart on my '09 RT. There's a boat load of screws and some are different lengths. Don't mix up the screws as a longer screw put where it doesn't belong will poke a hole in the outside of your case. Either draw a diagram, or take a piece of cardboard and shove the screws in the same place for re-installing later. Careful of the retracting cover strap. Its spring loaded. Just unclip it from the cover, but DO NOT REMOVE OR UNSCREW the base. The coiled up spring will un-spring, and its a real pain to get it re-wound. Link to comment
