Aled Williams Posted January 26, 2020 Share Posted January 26, 2020 My bad - I washed the bike but didn't dry it sufficiently. Now the right cylinder wont fire - engine runs on one cylinder with a bit of throttle. I've taken the body panels off and WD40'd all the obvious connections around the cylinder (I'm assuming that it's water in the electrics somewhere). Is there a specific 'culprit' that I should investigate/dry out? I'm new to this bike (2006 RT) so still finding my way around it. Many thanks, Aled Link to comment
dirtrider Posted January 26, 2020 Share Posted January 26, 2020 38 minutes ago, Aled Williams said: My bad - I washed the bike but didn't dry it sufficiently. Now the right cylinder wont fire - engine runs on one cylinder with a bit of throttle. I've taken the body panels off and WD40'd all the obvious connections around the cylinder (I'm assuming that it's water in the electrics somewhere). Is there a specific 'culprit' that I should investigate/dry out? I'm new to this bike (2006 RT) so still finding my way around it. Many thanks, Aled Afternoon Aled You definitely got something wet. Do both side exhaust pipes get hot, or one side hot & the other side warm, or one side completely cold? It's very unusual to wet out BOTH upper & lower spark plugs on the same cylinder so there might something else going on. If you have a gas or electric leaf blower try removing the plastic upper spark plug cover then blowing the spark plug well out with the high speed air from the leaf blower (that usually dries the spark plug area out). If you can get it running on both side cylinders then the engine heat from running will usually dry the lower spark plug area out. Link to comment
Aled Williams Posted January 26, 2020 Author Share Posted January 26, 2020 Thanks for your reply dirtrider, much appreciated - one side hot, the other cold - I'll apply the air/heat treatment as you suggest tomorrow morning. Link to comment
dirtrider Posted January 26, 2020 Share Posted January 26, 2020 2 minutes ago, Aled Williams said: Thanks for your reply dirtrider, much appreciated - one side hot, the other cold - I'll apply the air/heat treatment as you suggest tomorrow morning. Afternoon Aled If drying the spark plug area out doesn't help then maybe look a your R/H throttle body to make sure that the plastic cable cam hasn't disintegrated & fallen apart. Link to comment
Rougarou Posted January 27, 2020 Share Posted January 27, 2020 22 hours ago, Aled Williams said: My bad - I washed the bike but didn't dry it sufficiently. Now the right cylinder wont fire - engine runs on one cylinder with a bit of throttle. I've taken the body panels off and WD40'd all the obvious connections around the cylinder (I'm assuming that it's water in the electrics somewhere). Is there a specific 'culprit' that I should investigate/dry out? I'm new to this bike (2006 RT) so still finding my way around it. Many thanks, Aled See signature Link to comment
Tpoppa Posted January 27, 2020 Share Posted January 27, 2020 I used to own a self serve car wash. I had signs that said don't wash motorcycle engine with the high pressure wand. Lots of motorcycle wouldn't start afterwards. They were usually fine after everything dried out. Link to comment
Aled Williams Posted January 27, 2020 Author Share Posted January 27, 2020 Guys, guys, guys! Hold up! The bike really needed a clean. (Seven and a half hour ride on wintry UK roads) And the frustrating thing is, I only used a bucket and brush. Love the bike tho... Link to comment
Rougarou Posted January 28, 2020 Share Posted January 28, 2020 1 hour ago, Aled Williams said: Guys, guys, guys! Hold up! The bike really needed a clean. (Seven and a half hour ride on wintry UK roads) And the frustrating thing is, I only used a bucket and brush. Love the bike tho... The natural rain woulda took care of that,......just give it time 2 Link to comment
Aled Williams Posted January 28, 2020 Author Share Posted January 28, 2020 Wahey! Happy days... The bike started tonight and ran fine - phew! Thank you all for your support and encouragement, I'm sure I'll be back with more inane questions. I'll never wash the bike again... 3 Link to comment
Hosstage Posted January 29, 2020 Share Posted January 29, 2020 It's ok to wash it, just don't blast it with the hose. I use a gentle flower sprinkler nozzle on the end of the hose that allows the water to cascade over the bike, rather than a pressure washer style of nozzle. Even using a hose with no nozzle works. This method also cuts down on water spots. Link to comment
