ncsonderman Posted April 27, 2006 Share Posted April 27, 2006 Well I've done it. Both my first valve adjustment (went great!), and my first stripped cylinder cover screw . I know, I know... I was warned about overtightening the damn things. I glanced at the wrong torque value in the manual when putting the cover back on and set the wrench at 20Nm. Could have been the liquid refreshments or the lack of sleep getting to me. Probably just haste. Three of the four will still set at 8Nm but the lower front will not. The questions that I have revolve around fixing the strip. I've run a search on helicoils and come up empty. The screw is not free spinning, but probably will vibrate quite loose when the engine is running. Can I ride with this problem? How far/hard? Any estimates on dealer charges to fix this? Is there anyone close enough to Winston-Salem to give me a good smack accross the face? I've learned enough not to do this again though. Link to comment
adkbeemer Posted April 27, 2006 Share Posted April 27, 2006 oh, don't worry this is a common mistake , don't ask me how I know! Forget the dealer...just go and get yourself a helicoil kit (Autozone has them...?) If I remember it is the 6.0mm X 1 size. Easy to install, just make sure to shield the area when you drill so you dont get any metal flakes thrown into the works. First measure the depth of the current hole and mark the bit so you dont overdrill. Use lots of oil, it will catch most of the flakes on the drill bit, then use q-tip soaked in oil, dental instrument, etc to clean out the hole. Then use the tap provided with the kit (slow goes it...)to tap the hole and insert the helicoil with the provided tool. Break off the tang and your good to go! Big things are to go slow, make sure the drill and tap are properly aligned. Good luck! In the future, just tweak the screw after it bottoms out... Link to comment
ncsonderman Posted April 27, 2006 Author Share Posted April 27, 2006 Thanks for the words of comfort! I still need slapped since I was using a torque wrench and just looked at the wrong torque value. You know the old saying: "Haste makes a couple trips to Autozone" or something like that . This isn't as bad as the time that I cracked my oilpan on my CBR600F2 while prepping the night before a couple of track days at Nelson's Ledges. I overtightened the oil drain plug that time. Doh! Link to comment
Juan_in_a_million Posted April 27, 2006 Share Posted April 27, 2006 oh, don't worry this is a common mistake ... If I remember it is the 6.0mm X 1 size. That's is correct. 6mm 1mm pitch. Pep Boys also have them. As said before don't feel too bad. After you install the helicoil you will have a more substantial fastener than before. Some people systematically replace all aluminum low diameter threads with helicoil directly. Juan Antonio Link to comment
Rob L Posted April 27, 2006 Share Posted April 27, 2006 Your avatar explains the overtightening tendency Link to comment
randy Posted April 27, 2006 Share Posted April 27, 2006 some additional items from my experience the length of the helicoil is different. for example I think the Pep Boys is 6mm long. The NAPA is 9mm, and the best (in my opinion) Mcmasters is 12mm long. If you use either the 9mm or 12mm length helicoil you can just bottom out the helicoil and not worry about breaking off the tang. As noted above I have replaced all 4 on one side and used the 12mm length items and it has been great. I have a pep boys kit, a NAPA kit, and the McMasters helicoil items. Overall I have liked the combination of the NAPA kit, with the longer 12mm Mcmaster items. that combination has been the best for me. Link to comment
DavidEBSmith Posted April 27, 2006 Share Posted April 27, 2006 The mechanics around here prefer Time-Serts to Heli-Coils for this repair because the Time-Sert is a solid bushing, although they're harder to find than Heli-Coils. Link to comment
ncsonderman Posted April 27, 2006 Author Share Posted April 27, 2006 This is the step that I didn't watch at the Atlanta Tech Day in Chris' building. Just think of the knowledge that I'll be passing on the next time around ! Thanks for the advice Randy. Link to comment
ncsonderman Posted April 27, 2006 Author Share Posted April 27, 2006 David, I'll take a look for them. They look like a great option to use. I'll be happy with whatever I get my paws on quickly . Have you ever heard of an Apple pancake from Walkers? There was a blurb about them in last months Playboy. Tasty! Oh, yes, so are the pancakes ! Link to comment
bmweerman Posted April 27, 2006 Share Posted April 27, 2006 The mechanics around here prefer Time-Serts to Heli-Coils for this repair because the Time-Sert is a solid bushing, although they're harder to find than Heli-Coils. From experience I would soooooooooo recomend this over helicoils.. They're not hard to find. If you have trouble finding them PM me and I'll help you out. Link to comment
D. Boss Posted April 27, 2006 Share Posted April 27, 2006 I did the same thing you did-misread the tourque spec.I would recommend putting grease on the drill bit to catch the metal pieces. Worked great for me. The hardest part is getting over the uneasiness of actually drilling out the hole. Link to comment
RFW Posted April 27, 2006 Share Posted April 27, 2006 Don't forget to use a bit of oil on the tap when you are tapping with the Helioil tap. The procedure is to line the tap up straight, then go in enough to ensure the tap is not wobbly (a couple of turns or so) then after that, back off the tap a half turn to break the chips, for every turn or so that you screw it in. If you don't break the chips in this way, the tap can become progressively harder and harder to turn, and you risk messing up the tapped threads. The tap should go in relatively easy.... remember, broken taps are a real pain to extract! Also, keep an eye on the thing when you are tapping, to ensure it continues to go in straight. Bob. Link to comment
Mulepick Posted April 28, 2006 Share Posted April 28, 2006 Heli-coils? Dang we're only talking about taking an 8 Nm bite here. Sure you want to risk sending a steel bit into an Al cylinder for 8Nm? NAPA sells a 3-part "Stripped Bolt Repair Kit" that will give you your threads back and easily take 8Nm of torque. My two senses... Bob Link to comment
ncsonderman Posted April 28, 2006 Author Share Posted April 28, 2006 I'm going to try and find the time certs. I was unable to purchase any heli coils at either O'Reilly or Advance auto stores. I guess that I haven't tried autozone yet. This weekend looked so nice to ride too! Link to comment
DaveyMac Posted April 28, 2006 Share Posted April 28, 2006 If you go to Timesert Web Site and call them they will sell and ship to you. DaveMac Link to comment
RFW Posted April 28, 2006 Share Posted April 28, 2006 Heli-coils? Dang we're only talking about taking an 8 Nm bite here. Sure you want to risk sending a steel bit into an Al cylinder for 8Nm? NAPA sells a 3-part "Stripped Bolt Repair Kit" that will give you your threads back and easily take 8Nm of torque. It's not like tapping a hole in aluminum requires any real talent! Bob. Link to comment
bmweerman Posted April 28, 2006 Share Posted April 28, 2006 If you go to Timesert Web Site and call them they will sell and ship to you. DaveMac Really? I had to go through 3rd party in California...still got the kit in 2 days. You must be more charming Link to comment
ncsonderman Posted April 28, 2006 Author Share Posted April 28, 2006 Nothing at the local Harbor Freight store. Ordered the M6 x 1.0 Kit and Tap Guide from Time Cert just now. Kit includes 5 inserts at 12mm long and all the goodies to put it in. Including UPS 2nd day air I'm only out about $80. I should be back on the road next Wednesday. Maybe I should hit the treadmill this weekend so it will feel like I've picked up a couple of horsepower on the RT ! Link to comment
Beemeroil Posted April 28, 2006 Share Posted April 28, 2006 Welcome to an ever expanding club. Link to comment
bmweerman Posted April 28, 2006 Share Posted April 28, 2006 Maybe I should hit the treadmill this weekend so it will feel like I've picked up a couple of horsepower on the RT ! LOL Good job! And, I second what Beemeroil said, Welcome to the club!! Wanna do a spine lube next? Link to comment
DaveyMac Posted April 30, 2006 Share Posted April 30, 2006 Really? I had to go through 3rd party in California...still got the kit in 2 days. You must be more charming Im a Real Jem You don't even know Link to comment
psyctrance Posted May 3, 2006 Share Posted May 3, 2006 Just received my Time-Serts yesterday from http://www.madsens1.com/tsert.htm I have no affiliation, just a satidfied customer. Untill that is I do the job this weekend. Link to comment
ncsonderman Posted May 8, 2006 Author Share Posted May 8, 2006 I got my time certs on Tuesday and finally got time to do it on Friday (before celebrating cinqo de mayo). The process could not have been easier! Just have to make sure that your tap wrench has enough neck to clear the valve cartridge. The bike is definately smoother than when the dealer took care of it. I can't wait to do another adjustment. Only problem is now I've noticed that I have a small fuel leak from the intake line. It looks to be just a problem with the hose. I'll get it worked out. Next project please! Link to comment
ncsonderman Posted May 8, 2006 Author Share Posted May 8, 2006 Thanks for suggesting the time certs, they are great! I ended up using a bunch of Q-tips to clean out the shavings. I also used a cutting oil which kept the shaving tacky. After the retap, I used compressed air to blow out debris (I held an index card strategically blocking the valves). Cant't wait to do it again! Wait, what the hell am I thinking I'll always remember the torque value now! Link to comment
DavidEBSmith Posted May 8, 2006 Share Posted May 8, 2006 Now you don't need to remember the torque value, at least on that one screw. Link to comment
psyctrance Posted May 8, 2006 Share Posted May 8, 2006 Just did mine yesterday as well, piece of cake. Checking the valve adjustment took longer which fortunatley didn't need any adjustment. The bike has 92K on it so things have likely take a set. Link to comment
