ED P Posted January 6, 2020 Share Posted January 6, 2020 I have a brake fluid leak on the abs unit. It's on the output side to the front wheel. (see attached) any suggestions? The bike been sitting for 3+ years so the seal could be bad, but doesn't appear to be. On the same note is there a special wrench to remove the quick disconnect? Link to comment
dirtrider Posted January 6, 2020 Share Posted January 6, 2020 1 hour ago, ED P said: I have a brake fluid leak on the abs unit. It's on the output side to the front wheel. (see attached) any suggestions? The bike been sitting for 3+ years so the seal could be bad, but doesn't appear to be. On the same note is there a special wrench to remove the quick disconnect? Evening Ed It is usually the gasket ring down in the module side quick disconnect that seeps. (P/N 34517661 591 GASKET RING) You don't want to remove that module disconnect if at all possible as there are no parts available to service it. Link to comment
