TEDZ Posted December 22, 2019 Share Posted December 22, 2019 With the clutch lever pulled in, the starter won’t kick in unless the bike is in neutral. The neutral light and the gear indicator function. The side stand is up when trying to start it. Bought it out of state, so didn’t get a test ride. I’m thinking a bad clutch lever switch. Any other ideas? . Link to comment
Pappy35 Posted December 22, 2019 Share Posted December 22, 2019 What year? Oh, and yes, that does sound like a clutch switch problem. Link to comment
dirtrider Posted December 22, 2019 Share Posted December 22, 2019 11 hours ago, TEDZ said: With the clutch lever pulled in, the starter won’t kick in unless the bike is in neutral. The neutral light and the gear indicator function. The side stand is up when trying to start it. Bought it out of state, so didn’t get a test ride. I’m thinking a bad clutch lever switch. Any other ideas? . Morning TEDZ If the engine doesn't stall when you put the transmission in gear then it does point to the clutch switch circuit. Usually the clutch switch itself but not conclusive as it could be an open in the wiring or connector going to the clutch switch. Was your motorcycle shipped or trailered to you? If so was the motorcycle (incorrectly) restrained with tie-down straps to the handlebar area? If so then possibly a strap damaged the wiring in the clutch switch area. Makes sure that the switch connector is fully plugged into the switch, if still a no start then sometimes lightly (very little) bending the reed on the clutch switch to allow it to depress the little button in farther can get them functioning again. Link to comment
TEDZ Posted December 22, 2019 Author Share Posted December 22, 2019 It was on the top deck of the truck, so I didn’t see how it was strapped down. I turned the small clutch lever adjustment knob out a turn, pumped the lever about six times, and it’s working now. If it gets bad again, I’ll try adjusting the switch. Thanks for the info. Now to sell my 2008 RT. Link to comment
