sscheffing Posted December 8, 2019 Share Posted December 8, 2019 Hello, trusty 2000 BMW R1100RT (43,000 miles) no longer starts and has me stumped. I'm no BMW service tech but I do my own wrenching since 1974. Fuel pump will not turn on (for the 2 seconds) when ignition is turned on. Bikes remainging electrical systems are functions perfectly. I have completed the following procedures: Tested and swapped fuses and relays all are good By passed side stand switch--it is working as designed Replaced hall sensor (it was not toasted but appeared one wire had failed or was ready to) By-passed bike electrics and attached 12V power to pump---it sounds like it is running fine. Spark plugs are firing. Bike will try to run with a little gas sprayed into throttle bodies. Any suggestions would be greatly appreciated. Link to comment
dirtrider Posted December 8, 2019 Share Posted December 8, 2019 1 hour ago, sscheffing said: Hello, trusty 2000 BMW R1100RT (43,000 miles) no longer starts and has me stumped. I'm no BMW service tech but I do my own wrenching since 1974. Fuel pump will not turn on (for the 2 seconds) when ignition is turned on. Bikes remainging electrical systems are functions perfectly. I have completed the following procedures: Tested and swapped fuses and relays all are good By passed side stand switch--it is working as designed Replaced hall sensor (it was not toasted but appeared one wire had failed or was ready to) By-passed bike electrics and attached 12V power to pump---it sounds like it is running fine. Spark plugs are firing. Bike will try to run with a little gas sprayed into throttle bodies. Any suggestions would be greatly appreciated. Afternoon sscheffing I am about to go off the grid for a while so I can get you started on your further troubleshooting but I might not be back for a while. Easiest place to start is to see if the fuel pump relay is being triggered by the fueling-computer so put a 12v test light (or a voltmeter) on the green/white wire going to one of the fuel injectors. See if you have 12v on the green/white injector wire for a couple of seconds at key-on, then stays on during engine cranking. This will hopefully will tell us on what side of the fuel pump relay that your problem lies. If no 12v at key-on and during cranking then make sure the red wire (terminal 30) going to the fuel pump relay has 12v on it all the time (from fuse #6). Then make sure that terminal (86) green/yellow wire going to the fuel pump relay has 12v on it at key-on (all the time that key is on). This should get you started. Link to comment
sscheffing Posted December 8, 2019 Author Share Posted December 8, 2019 No power at injectors at key on or when cranking. Fuse 6 has power on both sides. Terminal 30 has no power at anytime. Guessing wire from fuse to terminal 30 has a short. Thanks for time and knowledge. I will try to learn how to disassemble fuse/relay panel to inspect wiring. Link to comment
dave_a Posted December 8, 2019 Share Posted December 8, 2019 Switch the horn relay & the fuel pump relay & see what happens. Link to comment
sscheffing Posted December 8, 2019 Author Share Posted December 8, 2019 Thank you Dave, I have 12 VDC at both sides of fuse, but none at the fuel pump relay. I have no idea how to get under the fuse/relay panel. Link to comment
