gettysburg Posted April 25, 2006 Share Posted April 25, 2006 One of the side cases on my R1200RT doesn't fit as snugly as the other. There is about 1/4" of play (up and down movement)when mounted. Does anyone know if the plastic flange which pops up, when the handle is locked, can be adjusted to stick out further? I sure miss the ammo-cans I had mounted to my F650GS; they were solid as a rock. Link to comment
Satguy Posted April 26, 2006 Share Posted April 26, 2006 No adjustment is available but that said, the two mounting "posts" that the side cases hang on are wedge shaped. The more load I carried in the side cases the tighter they sat on the bike. Was more difficult to get them off. I say not to worry about it, but just make sure that all three mounting points are properly engaged when you install the cases on the bike. Link to comment
