2020 Honda Montesa Cota 301RR And 4RT260 Trials Preview
MotoNews
The 2020 Honda Montesa trials bikes have just been released; if you have what it takes to tackle this challenging sport, then Honda has the bikes for you. Commemorating the 26th FIM World Championship won by Repsol Honda’s Toni Bou earlier this year, Honda is releasing the 4RT260 Race Replica in the distinctive Repsol colors, the more affordable 4RT260, and the new and improved 301RR for those of you who are ready to race right now.
“There’s only one Toni Bou, and for 2020 we’re proud to offer American trials enthusiasts the three Montesa Cota models that have directly benefited from the champ’s development input,” said Chris Cox, American Honda's manager of experiential marketing/public relations. “Whether it’s to tackle the AMA NATC MotoTrials series or to spend weekends on technical trails with your friends, no lineup of trials machines is better equipped to get the job done.”
Looking to get a little wild? The 2020 Honda Montesa Cota 301RR is the trials bike you’ve been waiting for.
Looking to get a little wild? The 2020 Honda Montesa Cota 301RR is the trials bike you’ve been waiting for. (Honda/)
All three motorcycles are built around the same twin-spar aluminum frame and single-cylinder engine with a five-speed transmission. The 301RR is a 299cc engine while the 4RT260 models feature a lower 258.9cc with smaller bore and shorter stroke, 39mm Showa fork, and Pro-Link system with a single Showa rear shock. All three models utilize a single 298mm front disc brake with four-piston caliper and a single 155mm rear disc with two-piston caliper.
The 2020 Honda Montesa Cota 301RR weighs in at 159 pounds (dry) while the 260 models tip the scales at 161 pounds. Each model has its unique color and stylized bodywork, with the 301RR being offered in Sonic Gray, the 4RT260 in Ross White with red and blue graphics, and the 4RT260 Race Replica in the traditional Repsol colors. Pricing has yet to be announced, but all three motorcycles will be available in April 2020.
The 2020 Honda Montesa Cota 301RR and 4RT260 trials bikes offer world-championship-winning pedigree to the common riders.The 2020 Honda Montesa Cota 301RR gets a power boost and brand-new Sonic Gray bodywork for 2020.The competition-focused 301RR (previously called the 300RR) is the most powerful Cota ever made.The new Honda Montesa Cota 301RR has a larger 299cc four-stroke engine that has been developed for competition by the greatest trials riders on the planet.Looking to get a little wild? The 2020 Honda Montesa Cota 301RR is the trials bike you’ve been waiting for.The 2020 Honda Montesa Cota 4RT260 incorporates all of Montessa’s trials experience and combines it with Honda's world-class engine.The 2020 Honda Montesa Cota 4RT260 is a fixture in the Honda Montesa trials lineup.For 2020, the Honda Montesa Cota 4RT260 gets new styling and updated engine mapping.You get improved engine and brake component protection with the new 2020 Honda Montesa Cota 4RT260.The 2020 Honda Montesa Cota 4RT260 Race Replica utilizes the same style bodywork as the 301RR but it gets the Bou-inspired Repsol Edition graphics.The 2020 4RT260 Race Replica is based on the standard 4RT260 but it has upgraded Showa suspension and Michelin tires.We had to include a few more photos of the 2020 Honda Montesa Cota 4RT260 Race Replica in action because it looks so good navigating these amazing trials obstacles.It looks like the 4RT260 Race Replica could just be set down on the starting line of an FIM World Trials event and give it a run.The 2020 4RT260 Race Replica continues a long tradition for Honda as the company enjoys promoting its racing partner, Repsol.
2020 Honda Montesa Cota 301RR (Montesa Cota 4RT260) Specifications
PRICE TBD
ENGINE 299cc (258.9cc), SOHC, liquid-cooled, four-stroke single-cylinder; 4 valves
BORE x STROKE 81.5 x 57.2mm (78.0 x 54.2mm)
COMPRESSION RATIO 10.4:1 (10.5:1)
FUEL DELIVERY PGM-FI electronic fuel injection
CLUTCH 5-speed manual, constant mesh
TRANSMISSION/FINAL DRIVE 5-speed/chain
FRAME Twin-spar aluminum
FRONT SUSPENSION Aluminum stanchions, adjustable for spring preload, compression, rebound damping; 6.6-in. travel (Formula Tech 39mm telescopic fork adjustable for spring preload, rebound damping; 6.6-in. travel) (4RT260RR: Showa 39mm telescopic fork adjustable for spring preload, rebound damping; 6.6-in. travel)
REAR SUSPENSION Pro-Link system w/ single Showa shock, adjustable for spring preload, rebound damping; 6.7-in. travel (Pro-Link system w/ single R16V shock)
FRONT BRAKE 4-piston hydraulic caliper, 185mm petal-style disc w/ sintered metal pads (4 piston hydraulic caliper, 185mm disc w/ sintered metal pads)
REAR BRAKE 2-piston hydraulic caliper, 150mm petal-style disc
WHEELS, FRONT/REAR Die-cast aluminum; 2.75 x 21-in. / 4.00 x 18-in.
TIRES, FRONT/REAR Michelin (Dunlop); 80/100-21 / 120/100R-18
RAKE/TRAIL N/A
WHEELBASE 52.0 in.
SEAT HEIGHT N/A
FUEL CAPACITY N/A
CLAIMED DRY WEIGHT 159 lb. (161 lb.)
WARRANTY TBD
AVAILABLE TBD
CONTACT https://powersports.honda.com/
View the full article
