Flashlights For Your Garage, Emergency Kit, Or Home
MotoNews
Make light of a situation with some of these flashlights.
Make light of a situation with some of these flashlights. (DC Irwin/Unsplash/)
Nowadays, cellphones conveniently have flashlight capability, but it drains the life out of its battery. How are you going to be able to make an emergency phone call or text if your phone’s battery is dead? It is wise to keep a good ol’ flashlight close by to light the way in this situation, but they are also useful around the house in the event of a power outage, at the campsite, or in the garage when you light up the space around your car’s belt drive. Flashlights from Anker, GearLight, and MagLite can brighten your world.
Anker Bolder Rechargeable LC40 Flashlight
Dusty, dry, or wet conditions, the Anker Bolder LC40 flashlight can assist in many dark places.
Dusty, dry, or wet conditions, the Anker Bolder LC40 flashlight can assist in many dark places. (Anker/)
The Bolder rechargeable LC40 flashlight from Anker is one great illuminating option to brighten your space with its 400-lumen LED. While it does not have the 900 lumens of the Anker LC90 flashlight in this list, the Bolder has adjustability with the high, medium, low, strobe, and SOS modes. In medium mode, this flashlight is claimed to last 20 hours on the 3350mAh battery. If the flashlight does start to lose juice, you can recharge it using the micro USB cable. Maintain your hold on the flashlight with the anti-slip finish. Rest assured that if it does drop, it is shock resistant and is built with a durable aluminum casing.
GearLight S1200 LED Flashlight
Focusing the beam or opening it up to light a larger space makes the GearLight a perfect option for the campsite.
Focusing the beam or opening it up to light a larger space makes the GearLight a perfect option for the campsite. (GearLight/)
A tight beam or a flood of light, the GearLight S1200 LED flashlight has the capability to narrow the beam or spray in a wider spectrum depending on your needs. The GearLight, too, has five modes (high, medium, low, strobe, and SOS). Water-resistant and durable with an aluminum body makes this flashlight appropriate for the rainy roadside emergency (because it always happens to rain when your tire decides to blow, right?).
Maglite LED 3-Cell Flashlight
Drop resistant and water resistant, the Maglite is another durable flashlight for your everyday use.
Drop resistant and water resistant, the Maglite is another durable flashlight for your everyday use. (MagLite/)
With an illuminating distance of 412 meters (~1,351 feet) this Maglite LED flashlight is a good one to have in your house, garage, or car’s glove box. Eighty hours of run time on high power make it a long-lasting light to keep around. Replaceable D cell batteries are the power source. This modern torch is available in blue, gray, red, silver, and camo.
Anker Bolder Rechargeable LC90 Flashlight
SOS or strobe modes are available in addition to high, medium, or low to suit your illumination needs.
SOS or strobe modes are available in addition to high, medium, or low to suit your illumination needs. (Anker/)
The 900 lumens pack a bright punch at the campsite with the Anker Bolder rechargeable LC90 flashlight. Zoomable capabilities allow you to focus in or spread light out. IP-65 rating ensures it is dust tight and water resistant for different conditions. After the six hours of battery life (in medium mode) has been used, recharging the tool is done by plugging in the micro USB cable into the port and power source.
View the full article
