geoff kooris Posted November 8, 2019 Share Posted November 8, 2019 I have a 99 R1100R. I put a hack on it, and I didn’t have a need for the kickstand, obviously. I removed the switch from the kickstand and reattached the wire so the bike will start. My question is, can I just put the two wires together so I won’t have to find a good place to stow the kill switch? Thanks, Geoff Link to comment
dirtrider Posted November 8, 2019 Share Posted November 8, 2019 8 hours ago, geoff kooris said: I have a 99 R1100R. I put a hack on it, and I didn’t have a need for the kickstand, obviously. I removed the switch from the kickstand and reattached the wire so the bike will start. My question is, can I just put the two wires together so I won’t have to find a good place to stow the kill switch? Thanks, Geoff Morning Geoff Sure, no problem. With no side stand there is no need to keep the factory switch. Just hook the wires together with a non-failing moisture proof connection. Link to comment
geoff kooris Posted November 8, 2019 Author Share Posted November 8, 2019 Thanks! It seemed obvious, but I wanted to check. Appreciate the reply! Link to comment
szurszewski Posted November 8, 2019 Share Posted November 8, 2019 2 hours ago, geoff kooris said: Thanks! It seemed obvious, but I wanted to check. Appreciate the reply! ...and now that you’ve solved that problem, how about showing us the hack? I’d be very interested if you happened to start a thread about it.... Link to comment
geoff kooris Posted November 10, 2019 Author Share Posted November 10, 2019 Spoiler Here’s my rig, all wired up. Windscreen and luggage rack to be added. 1 Link to comment
