Rube Posted November 6, 2019 Share Posted November 6, 2019 I am tucking my bike in for it's winter sleep. This BMW (2011 R1200RT) is new to me. All my other bikes usually have the batteries disconnected and hooked up to a trickle charger. I assume BMW has a preferred way of doing this. BMW charger and connection thru the power outlet??? What is the preferred method? Thx - Rube Link to comment
dirtrider Posted November 6, 2019 Share Posted November 6, 2019 2 minutes ago, Rube said: I am tucking my bike in for it's winter sleep. This BMW (2011 R1200RT) is new to me. All my other bikes usually have the batteries disconnected and hooked up to a trickle charger. I assume BMW has a preferred way of doing this. BMW charger and connection thru the power outlet??? What is the preferred method? Thx - Rube Depends on the battery access & how much stays powered with key-off. On easy to access battery's like on the 1200RT I usually just disconnect the battery (+) cable for winter storage. That removes power from everything. Sometimes you will need to re-set the service soon indicator after a long term battery disconnect & sometimes not (no real rhyme or reason) On your 'trickle charger'-- unless you have a 'smart' battery charger rated for your AGM battery then leaving a standard trickle charger hooked to your battery all winter will probably damage the battery due to sulfation issues. If you don't have a proper charger for your battery then do not leave it connected all the time. With battery disconnected from motorcycle you will only have to re-charge about every month or so. Link to comment
Rube Posted November 6, 2019 Author Share Posted November 6, 2019 haven't looked at the battery but it is the original 2011 factory battery... Link to comment
Rinkydink Posted November 7, 2019 Share Posted November 7, 2019 2011?? Wow, that has to be a record. Say it isn’t so... Link to comment
Rube Posted November 7, 2019 Author Share Posted November 7, 2019 original brakes...30,500 miles. Bike was a commuter before I got it. Link to comment
dirtrider Posted November 7, 2019 Share Posted November 7, 2019 13 hours ago, Rube said: haven't looked at the battery but it is the original 2011 factory battery... Morning Rube I would be VERY surprised if that battery is still original as that bike came with an Excide Gel battery. If in fact that battery is still original then you have probably set some kind of world record for an OEM Excide Gel battery. If your bike still has the original Gel battery then it is even more important to use the correct (Gel rated) battery charger (but no matter the charger used it will be a miracle if it survives another storage period). Link to comment
Skywagon Posted November 7, 2019 Share Posted November 7, 2019 if that battery is 8 (maybe 9 by spring) years old, I wouldn't worry about winter maintenance. I would plan on replacement when you are ready to take it out next spring. Some folks change the oil and ride it once for circulation before storage. Other than that not much to do. Check cables for corrosion. Link to comment
bruce2000ltc Posted November 8, 2019 Share Posted November 8, 2019 My '13RT has its original battery and it's still going strong. I checked my manual and the bike was put into service in Jan. 2013. I've thought about replacing it but since I carry a jump starter battery pack in my tank bag I don't worry about being stranded. The one I have is about the size of my iphone but slightly thicker. I've used it to start cars, trucks and a few motorcycles -- the thing is amazing. I bought it on Amazon a few years ago for less than fifty bucks. Gives you peace-of-mind when you have an older battery. Link to comment
Rougarou Posted November 8, 2019 Share Posted November 8, 2019 On my '06, the battery was original until it started slow cranking, it was replaced Feb 2014. If I recall, the battery had a sticker on it from 11/05. Bike was manufactured 2/06. Link to comment
