Sign in to follow this
MotoNews
2020 Suzuki V-Strom 1050XT First Look Preview Photo Gallery
MotoNews
The 2020 V-Strom 1050XT Adventure is the most sophisticated adventure bike Suzuki has ever built. It is still powered by the popular 90-degree V-twin, but this version is equipped with the latest rider assist technology.
The 2020 V-Strom 1050XT Adventure is the most sophisticated adventure bike Suzuki has ever built. It is still powered by the popular 90-degree V-twin, but this version is equipped with the latest rider assist technology. (Suzuki/)The riding position has been updated as well. A new tapered handlebar offers improved control while providing an off-road appearance.
The riding position has been updated as well. A new tapered handlebar offers improved control while providing an off-road appearance.The new height-adjustable windscreen was developed in a wind tunnel to make sure it reduces wind noise and buffeting to the rider. It can be adjusted, by hand, to 11 different positions. The base model 1050 is shown here.
The new height-adjustable windscreen was developed in a wind tunnel to make sure it reduces wind noise and buffeting to the rider. It can be adjusted, by hand, to 11 different positions. The base model 1050 is shown here.This version of the V-twin features exhaust and intake camshafts that are changed so that valve lift is increased and as a result, the valve-timing has less overlap. This increases engine power while reducing fuel consumption.
This version of the V-twin features exhaust and intake camshafts that are changed so that valve lift is increased and as a result, the valve-timing has less overlap. This increases engine power while reducing fuel consumption.The V-Strom 1050 XT instrument panel displays information on cruise control, Hill Hold System, Slope Dependent Control System, Load Dependent System, and the Motion Track Anti-lock and Combination Brake System sensitivity.
The V-Strom 1050 XT instrument panel displays information on cruise control, Hill Hold System, Slope Dependent Control System, Load Dependent System, and the Motion Track Anti-lock and Combination Brake System sensitivity.The two-piece seat provides improved comfort for the rider and passenger. The rider’s section is height-adjustable by 20mm.
The two-piece seat provides improved comfort for the rider and passenger. The rider’s section is height-adjustable by 20mm.The charging system uses a durable, three-phase stator with an open-style regulator/rectifier that reduces mechanical drag and heat while producing higher output at lower engine speeds.
The charging system uses a durable, three-phase stator with an open-style regulator/rectifier that reduces mechanical drag and heat while producing higher output at lower engine speeds.Bridgestone Battlax Adventure A41 tires are fitted to D.I.D. spoke-wheels with aluminum, tubeless-style wheel rims.
Bridgestone Battlax Adventure A41 tires are fitted to D.I.D. spoke-wheels with aluminum, tubeless-style wheel rims.Tokico Monoblock, four-piston calipers and 310mm floating-mount dual discs provide impressive stopping power. They work with the Motion Track Anti-lock and Combination Brake System for enhanced stopping performance.
Tokico Monoblock, four-piston calipers and 310mm floating-mount dual discs provide impressive stopping power. They work with the Motion Track Anti-lock and Combination Brake System for enhanced stopping performance.There are plenty of Genuine Suzuki Accessories for the new 1050XT including luggage, heated grips, along with high- and low-profile seats, auxiliary lights.
There are plenty of Genuine Suzuki Accessories for the new 1050XT including luggage, heated grips, along with high- and low-profile seats, auxiliary lights.The 2020 V-Strom 1050XT uses lightweight, low-draw LED turn signals and lights that are brighter than the previous model.
The 2020 V-Strom 1050XT uses lightweight, low-draw LED turn signals and lights that are brighter than the previous model.The 2020 V-Strom 1050 fuel tank provides a 5.3-gallon capacity. Despite the size, the actual cover have been designed to offer a slim tank-to-seat point that enhances rider comfort.
The 2020 V-Strom 1050 fuel tank provides a 5.3-gallon capacity. Despite the size, the actual cover have been designed to offer a slim tank-to-seat point that enhances rider comfort.Hill Hold Assist: When stopping upward on a hill and applying the brakes, this system automatically operates the rear brake for around 30 seconds to prevent the motorcycle from rolling back down the hill even if the rider releases the brake lever or pedal. This allows the rider to focus on a smoother takeoff when on the hill side.
Hill Hold Assist: When stopping upward on a hill and applying the brakes, this system automatically operates the rear brake for around 30 seconds to prevent the motorcycle from rolling back down the hill even if the rider releases the brake lever or pedal. This allows the rider to focus on a smoother takeoff when on the hill side.The 43mm KYB inverted front fork are adjustable for spring preload plus compression and rebound-damping.
View the full article
Share this post
Link to post
