Sign in to follow this
MotoNews
Limited Edition Triumph Factory Custom Bobber
MotoNews
2020 Triumph Bobber TFC.
2020 Triumph Bobber TFC. (Triumph/)
Triumph has unveiled a limited edition 2020 Bobber Triumph Factory Custom at this year's [EICMA] (https://www.motorcyclistonline.com/eicma/) show in Milan, Italy. The Bobber TFC has an impressive roster of upgrades that touch nearly every part of the motorcycle. Only 750 units will be created worldwide, and each will come with a special numbered plaque and an accessory pack including a hand-signed letter from Triumph CEO Nick Bloor, a custom build book, Bobber TFC bike cover, along with a TFC document wallet and leather TFC rucksack.
Mechanical Upgrades
The Bobber TFC has upspec components and aesthetic upgrades.
The Bobber TFC has upspec components and aesthetic upgrades. (Triumph/)
While the enhanced aesthetic of the Bobber TFC would be enough for it to stand out from the pack, a handful of mechanical refinements result in an improved performance package as well.
The engine receives a lighter crankshaft, clutch, balance shafts, alternator, magnesium cam cover and thin-walled engine covers. Triumph claims 10 more horsepower from the refined mill compared to the stock [Bobber] (https://www.motorcyclistonline.com/2017-triumph-bonneville-bobber-first-ride-review/), as well as 3 more pound-feet of torque. The rev limiter is also 500 rpm higher than stock.
Only 750 units of this limited edition machine will be produced worldwide.
Only 750 units of this limited edition machine will be produced worldwide. (Triumph Motorcycles/)
The exhaust silencers come from Arrow, complete with carbon fiber end-caps that tie in nicely with the blacked-out aesthetic of the bike.
Additionally, the Bobber TFC receives fully adjustable Öhlins suspension, front and rear, Brembo M50 radial monobloc calipers and a Brembo radial master cylinder.
Weight savings over stock, thanks to the engine components the addition of carbon fiber elements in key areas, is 11 pounds. However, Triumph won’t release the final weight, trail, rake, and seat height specs until hololgation in January 2020.
Electronics Enhancements
A sharp looking Bobber.
A sharp looking Bobber. (Triumph/)
The Bobber TFC will feature Sport riding mode, giving it three total ride modes: Rain, Road, and Sport.
Triumph utilizes LED lighting throughout and upgraded the instrument panel to a TFC-branded unit that incorporates a digital menu system.The TFC also has ABS, traction control, and a torque-assist clutch.
Fit and Finish
Union Jack and TFC badging break-up the blacked-out aesthetic.
Union Jack and TFC badging break-up the blacked-out aesthetic. (Triumph/)
As with all [Triumph Factory Custom] (https://www.motorcyclistonline.com/2019-triumph-factory-custom-thruxton-first-look/) machines, the Bobber TFC is thoroughly upgraded in the looks department.
Carbon fiber side panels and mudguard supports incorporate with the knurled design of the handlebar grips, black engine covers, frame, anodized multi-spoke wheels, and swingarm. Billet aluminum is used for the yokes and oil reservoir cap. The Black and Matte Carbon Black colorway is accented by a silver foil Union Jack flag on the tank, with gold pinstriping and TFC logos adding some additional visual interest.
2020 Triumph Bobber TFC Specifications
Price TBD
Engine 1,200cc, liquid-cooled parallel twin, SOHC, 8 valves/cylinder
Bore x Stroke 97.6mm x 80.0mm
Clutch Wet, multi-plate assist clutch
Fuel Delivery Multi-point sequential EFI, ride by wire
Transmission/Final Drive 6 speed/chain
Frame Tubular-steel cradle
Front Suspension Öhlins 43mm USD fork, fully adjustable
Rear Suspension Öhlins RSU, rebound and preload adjustable
Front Brake Brembo M50 four-piston radially mounted Monoblock calipers, dual 310mm discs w/ ABS
Rear Brake Nissin single piston floating caliper, 255mm disc w/ ABS
Wheels, Front/Rear 3.50 x 17 in. / 5.50 x 17 in.
Tires, Front/Rear 100/90-19 front, 150/80-16 rear
Rake/Trail TBC
Seat Height TBC
Claimed Curb Weight TBC
Available TBD
The 1,200cc engine receives a number of lighter parts, and yields more power and torque.
The 1,200cc engine receives a number of lighter parts, and yields more power and torque. (Triumph/)A custom leather seat is adjustable.
A custom leather seat is adjustable. (Triumph/)The Bobber TFC has an additional ride mode over stock.
The Bobber TFC has an additional ride mode over stock. (Triumph/)Billet aluminum yokes add a refined feel.
Billet aluminum yokes add a refined feel. (Triumph/)Every detail was considered.
Every detail was considered. (Triumph/)Gold striping and badging accent the black Bobber tank.
Gold striping and badging accent the black Bobber tank. (Triumph/)Arrow exhaust with carbon fiber end-caps.
Arrow exhaust with carbon fiber end-caps. (Triumph/)
View the full article
Share this post
Link to post
