Tush Posted June 4, 2020 Author Share Posted June 4, 2020 Good to know on the float vs sender unit. Thanks Yes, I am replacing the U hose with one from Beemer boneyard. If I had a do over, I would have simply got my little Dremel tool out and have cut that clamp off since I wasn’t re using the clamp or hose anyway. The clamps that come in the boneyard kits are fuel injection style clamps. I’m sure they will be more than adequate. Thanks for watching and commenting. I’ll get back to it once my parts arrive. Cheers, Tush Link to comment
Dave P Posted June 14, 2020 Share Posted June 14, 2020 Tush- Ive got a different take on the side stand interference. When I bought my 1100RT, the PO must have gotten irritated with that goofy wire thing and cut it off. I later welded on a flat plate so I could easily "toe" the sidestand down. I always am standing when I lower the Sidestand. Dave 1 Link to comment
bacos Posted June 14, 2020 Share Posted June 14, 2020 hey tush in the same boat at the same time, renovating a '04 RT at the moment, silver even. What I've noticed so far is that whatever list of stuff you make of things you need to do... it grows longer as you keep at it! Just an example - saw DR's mention of lubing the shift link here - since I have the left footpeg off already from the starter check... someday we'll get to ride them! 1 Link to comment
Tush Posted June 23, 2020 Author Share Posted June 23, 2020 Hi Guys, Part seven now out. Thanks to Spacewrench again for the assist. Cheers Tush 1 Link to comment
Miguel! Posted June 23, 2020 Share Posted June 23, 2020 Thanks Tush. So far, so good. Cheers. Miguel 1 Link to comment
Rollie Posted October 17, 2020 Share Posted October 17, 2020 Hi Tush, I’ve enjoyed all your BMW Videos. I just picked up an 2002. same exact bike. Only 19k on the odometer. Original owner says it hasn’t run for 4 years. From the looks of the gas tank and fuel pump it’s more like 14. never seen soooo much varnish. The hoses have actually discintigrated. turned to mush. But it does crank and I have spark. trying to get a pump from Beemer boneyard. They are out of stock on most parts I need. So it’s after market I guess. just wanted to thank your for the time and effort you put in your videos. I’ve seen some of your car restorations as well. wish me luck. Roll’in on the River! Link to comment
Tush Posted October 17, 2020 Author Share Posted October 17, 2020 Hi Rollie, Thanks for the kind words. Good luck with your project. Cheers, Tush Link to comment
joeb Posted October 17, 2020 Share Posted October 17, 2020 Welcome, I too have an 03 and going thru the process of what should I do, as my abs is failing. I have 113,000 miles on it and love the bike. I'm not sure on your model but you may have a repairable module . Modulemaster does repair some of the units. I'm sure someone on this forum knows. They dont repair mine. But I do like the abs brakes. Just took a little time to get used to them. You will enjoy the bike. Link to comment
