Sign in to follow this
MotoNews
2020 Arch KRGT-1 Preview Photo Gallery
MotoNews
There is no mistaking the 2020 Arch KRGT-1 for any other brand of motorcycle.
There is no mistaking the 2020 Arch KRGT-1 for any other brand of motorcycle. (Arch Motorcycle/)The concept behind Arch motorcycles includes custom-tailored ergonomic and aesthetic packages that are conceived and finalized along with the owner during the 90-day build process.
The concept behind Arch motorcycles includes custom-tailored ergonomic and aesthetic packages that are conceived and finalized along with the owner during the 90-day build process. (Arch Motorcycle/)Although there are three base models to choose from, each KRGT-1 will be unique to its owner. Everything from paint to riding position will be custom-tailored.
Although there are three base models to choose from, each KRGT-1 will be unique to its owner. Everything from paint to riding position will be custom-tailored. (Arch Motorcycle/)Providing the power behind the 2020 Arch KRGT-1 is still the company’s signature 124ci S&S/Arch V-twin engine.
Providing the power behind the 2020 Arch KRGT-1 is still the company’s signature 124ci S&S/Arch V-twin engine. (Arch Motorcycle/)The new 48mm Öhlins NIX fork is larger in diameter than the previous units.
The new 48mm Öhlins NIX fork is larger in diameter than the previous units. (Arch Motorcycle/)There are no less than 20 major changes and 150 newly designed components put into play on the 2020 Arch KRGT-1.
There are no less than 20 major changes and 150 newly designed components put into play on the 2020 Arch KRGT-1. (Arch Motorcycle/)The rear suspension of the 2020 KRGT-1 is an Öhlins fully adjustable shock that has been developed specially for Arch Motorcycle.
The rear suspension of the 2020 KRGT-1 is an Öhlins fully adjustable shock that has been developed specially for Arch Motorcycle. (Arch Motorcycle/)The new Arch KRGT-1 features completely redesigned bodywork, new suspension, ergonomics, brakes, and safety features including an all-new ABS system.
The new Arch KRGT-1 features completely redesigned bodywork, new suspension, ergonomics, brakes, and safety features including an all-new ABS system. (Arch Motorcycle/)Exhaust is expelled through a hand-built 2-into-1 stainless steel header and capped off with a trick Yoshimura carbon fiber muffler.
Exhaust is expelled through a hand-built 2-into-1 stainless steel header and capped off with a trick Yoshimura carbon fiber muffler. (Arch Motorcycle/)The new billet aluminum swingarm on the KRGT-1 is designed and manufactured by Arch, increases rigidity, and reduces unsprung weight.
The new billet aluminum swingarm on the KRGT-1 is designed and manufactured by Arch, increases rigidity, and reduces unsprung weight. (Arch Motorcycle/)The KRGT-1 chassis is equipped with redesigned in-house-machined billet aluminum side plates to accommodate the new swingarm pivot.
The KRGT-1 chassis is equipped with redesigned in-house-machined billet aluminum side plates to accommodate the new swingarm pivot. (Arch Motorcycle/)New dual ISR six-piston front brake calipers feature increased piston diameter which is intended to increase the bike’s impressive stopping power.
New dual ISR six-piston front brake calipers feature increased piston diameter which is intended to increase the bike’s impressive stopping power. (Arch Motorcycle/)The 2020 Arch KRGT-1 comes standard with two-channel ABS, which will improve braking performance and rider safety.
The 2020 Arch KRGT-1 comes standard with two-channel ABS, which will improve braking performance and rider safety. (Arch Motorcycle/)Some of the noticeable redesigned components include a redesigned aluminum fuel tank, sportier tail section, and an even more comfortable seat.
Some of the noticeable redesigned components include a redesigned aluminum fuel tank, sportier tail section, and an even more comfortable seat. (Arch Motorcycle/)The KRGT-1 front cowling has been redesigned and repositioned so that it can properly incorporate an all-new dash and headlight.
The KRGT-1 front cowling has been redesigned and repositioned so that it can properly incorporate an all-new dash and headlight. (Arch Motorcycle/)A bright, new J.W. Speaker Adaptive 2 headlamp adds to the high-tech looks of the KRGT-1 while vastly improving the rider’s view as he peers into the darkness of the road ahead.
A bright, new J.W. Speaker Adaptive 2 headlamp adds to the high-tech looks of the KRGT-1 while vastly improving the rider’s view as he peers into the darkness of the road ahead. (Arch Motorcycle/)The Magura clutch and front brake assembly offer a level of performance and feel that help the KRGT-1 continue to be one of the most rider-friendly performance cruisers on the market.
The Magura clutch and front brake assembly offer a level of performance and feel that help the KRGT-1 continue to be one of the most rider-friendly performance cruisers on the market. (Arch Motorcycle/)It’s all about the ride when you are at the controls of a motorcycle like the new and improved Arch KRGT-1.
It’s all about the ride when you are at the controls of a motorcycle like the new and improved Arch KRGT-1. (Arch Motorcycle/)Blackstone Tek (BST) five-spoke carbon fiber wheels and Michelin Commander II tires connect the new Arch KRGT-1 to the road.
Blackstone Tek (BST) five-spoke carbon fiber wheels and Michelin Commander II tires connect the new Arch KRGT-1 to the road. (Arch Motorcycle/)There are three base colors available for the KRGT-1, and if you look close you will notice the blue units come with black aluminum components.
There are three base colors available for the KRGT-1, and if you look close you will notice the blue units come with black aluminum components. (Arch Motorcycle/)The KRGT-1 has a completely reshaped 5.0-gallon aluminum fuel tank.
The KRGT-1 has a completely reshaped 5.0-gallon aluminum fuel tank. (Arch Motorcycle/)
View the full article
Share this post
Link to post
