Kitsap Posted April 24, 2006 Share Posted April 24, 2006 Out of the blue my neutral light won't go out when leaving neutral. In all gears it remains green. This is the same switch that was just replaced not long ago. I know its probably a deffective switch but please tell me it could be something else. Link to comment
LJR Posted April 24, 2006 Share Posted April 24, 2006 It's the switch. You can unplug it until you get it fixed, connector is near fuse box on left side. OR you can take light bulb out, however the bike will always think it's in neutral and might start at an inapropriate time. Link to comment
Ken H. Posted April 24, 2006 Share Posted April 24, 2006 its probably a deffective switch Yup. Sorry dude. Link to comment
bmwmick Posted April 24, 2006 Share Posted April 24, 2006 Out of the blue my neutral light won't go out when leaving neutral. In all gears it remains green. This is the same switch that was just replaced not long ago. I know its probably a deffective switch but please tell me it could be something else. Wade, That switch just provides a ground to light the neutral lamp. You 'might' just have a pinched wire before or after the connector. Unplug the connector and see if it still lights the lamp. If so, you have a short to ground BEFORE the connector. If the lamp is out with the connector unplugged, it's either a dead switch or one of the wires is shorted to ground AFTER the connector. Good luck. Mick Link to comment
