Sign in to follow this
MotoNews
2020 Ducati Streetfighter V4 First Look Preview
MotoNews
The 2020 Ducati Streetfighter V4 and Streetfighter V4S have officially arrived and they look incredible. As per the recipe, the bike is based on the Panigale V4 superbike minus bodywork, so we're sure it will offer more performance than many modern riders will ever be capable of tapping into, but hey, who cares, it's a Ducati!
If you have been waiting for a tire-destroying, knee-dragging, mind-melting riding experience, you may want to consider the brand-new 2020 Ducati Streetfighter V4.
If you have been waiting for a tire-destroying, knee-dragging, mind-melting riding experience, you may want to consider the brand-new 2020 Ducati Streetfighter V4. (Ducati/)
Related: Uncrating A $40,000 Ducati Panigale V4 Superbike
What's New About The 2020 Ducati Streetfighter V4?
The 2020 Ducati Streetfighter V4 may be tailored for street riding but you can rest assured it is more than a capable sport motorcycle if you want to play on your favorite track.
The 2020 Ducati Streetfighter V4 may be tailored for street riding but you can rest assured it is more than a capable sport motorcycle if you want to play on your favorite track. (Ducati/)
It may seem that simple but a lot of time and effort were put into deciding the exact bend and rise of the one-piece handlebar and more comfortable riding position. Then the engineers crafted a nifty new Panigale-inspired front headlight pod with LED running lights and placed a five-inch TFT dash from which you can monitor the various electronic functions deployed on both models. A comfortable seat creates the perfect perch for riders as they shred their way around their favorite roads or tracks in some serious Italian style.
2020 Ducati Streetfighter V4 Vs. Panigale V4 S
The V4S (left) has an Öhlins NIX 30 fork with Öhlins TTX 36 shock and forged Marchesini wheels. The V4 (right) uses Showa BFF fork and Sachs monoshock with plain alloy wheels.
The V4S (left) has an Öhlins NIX 30 fork with Öhlins TTX 36 shock and forged Marchesini wheels. The V4 (right) uses Showa BFF fork and Sachs monoshock with plain alloy wheels. (Ducati/)
Both versions are built around the same frame and chassis with a 208-hp 1,103cc Desmosedici Stradale 90-degree V-4 engine providing the power. The Panigale V4 and now the Streetfighter V4 feature the front frame design that uses the engine as a stressed member of the chassis uncovered by the sinister-looking lines of the minimalist bodywork.
The base-model Streetfighter V4 will come equipped with fully adjustable Showa suspension while the V4 S ups the ante with electronically adjustable Öhlins NIX 30 fork and TTX 36 shock. The V4 will roll on five-spoke alloy wheels (the most conspicuous way of differentiating between the models from a distance), and three-spoke Marchesini forged aluminum-alloy wheels for the V4S. Both bikes will be shod with Pirelli Diablo Rosso Corsa II rear tires and will be offered in the signature red colorway only.
2020 Ducati Streetfighter V4 Winglets
The biplane winglet aerodynamics were developed using CFD (Computational Fluid Dynamics) simulation in an effort to improve the Streetfighter V4’s stability at speed and under braking.
The biplane winglet aerodynamics were developed using CFD (Computational Fluid Dynamics) simulation in an effort to improve the Streetfighter V4’s stability at speed and under braking. (Ducati/)
Stare at the images long enough and you will see the biplane-style aerodynamic winglets being utilized on both models. Ducati claims they function by producing more than 60 pounds (28kg) of downforce at 165 mph (270 kph) which in turn reduces the bikes’ tendency to lift the front wheel under acceleration—which in turn reduces the amount of electronic intervention necessary to keep the front end down. The winglets also are supposed to improve the bikes’ stability during turn-in while on the brakes. Plus, they look pretty...interesting too.
The Streetfighter V4 adds an element of comfort into the superbike-style performance thanks to repositioned footpegs, the aforementioned one-piece bars, and a comfortable seat that is easy on your backside. The passenger perch rests on a steel subframe that offers a bit more room than what was found on the previous models. If you find someone brave enough to ride double on this motorcycle, it may be a good idea to make them your spouse immediately.
Unfortunately Ducati did not release information on price or availability at this time, but we are sure it will be worth the wait for the chosen folks who are willing to pay the price of admission for this ostentatious motorcycle.
Check out the official promotional video for a glimpse of why the Streetfighter V4 is destined to stir your soul…
2020 Ducati Streetfighter V4 Specifications
PRICE TBD
ENGINE 1,103cc liquid-cooled Desmosedici Stradale 90° V-4, rearward-rotating crankshaft, 4 desmodromically actuated valves/cyl.
BORE x STROKE 81.0 x 53.5mm
COMPRESSION RATIO 14.0:1
FUEL DELIVERY Electronic fuel injection system; twin injectors per cylinder; full ride-by-wire elliptical throttle bodies.
CLUTCH Hydraulically controlled slipper and self-servo wet multiplate clutch
TRANSMISSION/FINAL DRIVE 6-speed w/ Ducati Quick Shift (DQS) up/down EVO 2/chain
FRAME Aluminum alloy front frame
FRONT SUSPENSION V4: Fully adjustable 43mm Showa BPF fork / V4S: 43mm Öhlins NIX 30 fully adjustable w/ TiN treatment. Electronic compression and rebound damping adjustable w/ Öhlins Smart EC 2.0
REAR SUSPENSION V4: Fully adjustable Sachs shock; aluminum single-sided swingarm / V4S: Fully adjustable Öhlins TTX 36 unit. Electronic compression and rebound damping adjustable w/ Öhlins Smart EC 2.0 event-based mode; aluminum single-sided swingarm
FRONT BRAKE Radially mounted Brembo Monoblock Stylema M4.30 4-piston calipers, dual 330mm semi-floating discs, w/ Cornering ABS EVO
REAR BRAKE 2-piston caliper, 245mm disc, w/ Cornering ABS EVO
WHEELS V4: 5-spoke light alloy, 6.00 x 17 in. / V4S: 3-spoke forged aluminum alloy, 6.00 x 17 in.
TIRES, FRONT/REAR Pirelli Diablo Rosso Corsa II; 120/70ZR-17 / 200/60ZR-17
RAKE/TRAIL 24.0°/3.9 in.
WHEELBASE 58.6 in.
SEAT HEIGHT 33.3 in.
FUEL CAPACITY 4.2 gal.
CLAIMED CURB WEIGHT V4: 443 lb. / V4S: 439 lb.
WARRANTY 24 months
AVAILABLE TBD
From the TFT dash you can monitor Riding Modes, Power Modes, Cornering ABS EVO, Ducati Traction Control (DTC) EVO 2, Ducati Wheelie Control (DWC) EVO, Ducati Slide Control (DSC), Engine Brake Control (EBC) EVO, and Auto tire calibration.
From the TFT dash you can monitor Riding Modes, Power Modes, Cornering ABS EVO, Ducati Traction Control (DTC) EVO 2, Ducati Wheelie Control (DWC) EVO, Ducati Slide Control (DSC), Engine Brake Control (EBC) EVO, and Auto tire calibration. (Ducati/)The minimalist front end and full-LED headlight produces the signature scowl of the brand-spanking-new Streetfighter V4.
The minimalist front end and full-LED headlight produces the signature scowl of the brand-spanking-new Streetfighter V4. (Ducati/)The curvy yet high-tech design of the Streetfighter V4 offers a comfortable, narrow saddle-to-frame ratio that makes it easy to touch the ground—the passenger accommodations are improved as well.
The curvy yet high-tech design of the Streetfighter V4 offers a comfortable, narrow saddle-to-frame ratio that makes it easy to touch the ground—the passenger accommodations are improved as well. (Ducati/)Both of the Streetfighter V4 models utilize a pair of 330mm semi-floating discs, radial-mount Brembo Monoblock Stylema (M4.30) four-piston calipers with Cornering ABS EVO.
Both of the Streetfighter V4 models utilize a pair of 330mm semi-floating discs, radial-mount Brembo Monoblock Stylema (M4.30) four-piston calipers with Cornering ABS EVO. (Ducati/)Fully adjustable Öhlins TTX 36 shock features electronic compression and rebound damping adjustment with Öhlins Smart EC 2.0 event-based mode.
Fully adjustable Öhlins TTX 36 shock features electronic compression and rebound damping adjustment with Öhlins Smart EC 2.0 event-based mode. (Ducati/)<strong>Left:</strong> The minimalist bodywork bolted to the Streetfighter V4 reveals the unique look of the front frame and Desmosedici Stradale engine which creates the unique look of the latest-generation Streetfighter. <strong>Right:</strong> The latest-generation electronics package offered on the Streetfighter V4 is based on a six-axis Inertial Measurement Unit (6D IMU) which detects the bike's roll, yaw, and pitch.
<strong>Left:</strong> The minimalist bodywork bolted to the Streetfighter V4 reveals the unique look of the front frame and Desmosedici Stradale engine which creates the unique look of the latest-generation Streetfighter. <strong>Right:</strong> The latest-generation electronics package offered on the Streetfighter V4 is based on a six-axis Inertial Measurement Unit (6D IMU) which detects the bike's roll, yaw, and pitch. (Ducati/)The 2020 Streetfighter V4 incorporates the Ducati Quick Shift (DQS) up/down EVO 2 system to speed up gear shifts.
The 2020 Streetfighter V4 incorporates the Ducati Quick Shift (DQS) up/down EVO 2 system to speed up gear shifts. (Ducati/)The final gear ratios on the Streetfighter V4 are shorter than those of the Panigale V4. As a result you get more usable torque even lower in the rpm range. Good lord, that sounds like a recipe for some hooligan fun time.
The final gear ratios on the Streetfighter V4 are shorter than those of the Panigale V4. As a result you get more usable torque even lower in the rpm range. Good lord, that sounds like a recipe for some hooligan fun time. (Ducati/)From the beginning the 2020 Ducati Streetfighter V4 was destined to be a kick-ass-looking motorcycle…even in black and white.
From the beginning the 2020 Ducati Streetfighter V4 was destined to be a kick-ass-looking motorcycle…even in black and white. (Ducati/)
View the full article
Share this post
Link to post
