MBrockman5 Posted October 18, 2019 Share Posted October 18, 2019 Has anyone installed a Run-N-Lites Lite blazer on their license plate? My new 07 RT came with this (and a mountain of other stuff) that the previous owner didn't get around to install. Even though there are "instructions" online, they're just general info. I'm hoping someone has some experience and can simplify the hook up for me. There are 3 wires. Black, gray, and brown. Link to comment
KDeline Posted October 22, 2019 Share Posted October 22, 2019 I have this on an 1100 non Canbus. As far as I can tell and have tried, I cannot get this to work with Canbus, as there is not a separate positive tail light and brake light wire on the bike. Both are the same wire with Canbus system. Link to comment
dirtrider Posted October 22, 2019 Share Posted October 22, 2019 On 10/18/2019 at 12:29 PM, MBrockman5 said: Has anyone installed a Run-N-Lites Lite blazer on their license plate? My new 07 RT came with this (and a mountain of other stuff) that the previous owner didn't get around to install. Even though there are "instructions" online, they're just general info. I'm hoping someone has some experience and can simplify the hook up for me. There are 3 wires. Black, gray, and brown. Afternoon MBrockman5 It might work & it might not. You definitely can't use the 3 wires as you only have 2 wires going to your tail/brake light. If your LED array will light brightly at 12-14 volts & light with less intensity at about 6-8 volts then it will work on your motorcycle. Your 2007 1200RT has a pulse width modulated tail light (pulsed 8 volts or so for tail light, & on steady at 12+ volts for brake light )-- (has nothing to do with the CanBus). In any case, first identify the LED array ground wire then identify the high (bright) wire. Then, you need to either test it with a 12v & an 8V dc source, or test it on your motorcycle before installing. To test off the bike just hook the LED array ground wire to a 12v battery (-) & hook the LED high wire to the 12v battery (+) -- it should light brightly. (if it flashes then it is not easily usable without some modification) Next, repeat the above test using a 9v flashlight battery-- first, it should light at only 9 volts, & second it should show less brightness than it did at 12 volts. (you definitely need to see a brightness difference between 12v & 9v) If your LED array passes the above off-bike test then post back & we can give you the details on how to hook it to your bikes rear lighting harness for an on-bike test. If the light array flashes when using the high (brake) wire then you might need to re-run the above test using the low (tail light) wire. You won't be able to use the flashing part so that will have to be by-passed (or figured out then eliminated) There might be other options, like hooking the LED low to the rear accessory outlet B+ circuit & hooking the LED high to the rear brake/tail but that is sort of iffy if you don't understand the LED array internal circuitry. If the LED flashes with power to the LED high wire that really complicates the thing if you can't figure out how to eliminate the flashing. Link to comment
KDeline Posted October 23, 2019 Share Posted October 23, 2019 The only way I can use mine on a 2009 is as a bright tail light. Turn on ignition, it flashes as a brake then goes solid until the next power interruption, as in turn off then back on. Link to comment
MBrockman5 Posted October 28, 2019 Author Share Posted October 28, 2019 On 10/22/2019 at 5:33 PM, KDeline said: The only way I can use mine on a 2009 is as a bright tail light. Turn on ignition, it flashes as a brake then goes solid until the next power interruption, as in turn off then back on. KDeline... How did you wire it that way? In all honesty, I'd be fine with it as a "Bright tail light". It's better than having it sit on my desk unused. Link to comment
KDeline Posted October 29, 2019 Share Posted October 29, 2019 9 hours ago, MBrockman5 said: KDeline... How did you wire it that way? In all honesty, I'd be fine with it as a "Bright tail light". It's better than having it sit on my desk unused. It has been a while but I think I just connected both tail and brake light to a switched positive like your front parking lights as they are always 12 volts, then ground wire to ground. Check this on you battery positive and negative to verify. You could tap into the tail power socket but they will stay on for about 45 seconds till canbus shuts down. I believe there is a switched 12 volt wire in the tail section for the alarm you could use also. Brown to ground, black and gray to switched positive. DO NOT GROUND THE GREY WIRE EVER!!!! After more research it seems you can connect the black wire to a switched twelve volt source, grey to the brake light positive and brown to ground. This might let it work as it should. Wish I would have found that years ago..... Link to comment
MBrockman5 Posted November 20, 2019 Author Share Posted November 20, 2019 Thanks KDeline. I'll try that next time I have a chance. Maybe/hopefully over the holiday break or after finals (Frickin college . Always eating into my free time) Link to comment
MBrockman5 Posted February 11, 2020 Author Share Posted February 11, 2020 UPDATE: Success!!! I finally got around to wiring up the Run-N-Lites Lite Blazer today. Thanks to @dirtrider and @KDeline for the pointers. It was relatively simple to install and works great. Even though it lights up [BRIGHT] with the brake light, the "Flashing" feature doesn't appear to function. I used the screw next to the helmet lock for the Ground, tapped into the rear auxiliary power socket for Switched Power, and the wire that activates the LED's was tapped into the Positive wire to one of the tail light bulbs. What it looks like mounted. "Dimmed" with the running lights. Activated with brakes applied. Since I used the rear auxiliary power socket, it remains lit up for about 45 seconds after the bike is turned off. Link to comment
