beemerman2k Posted October 15, 2019 Share Posted October 15, 2019 My console lit up to suggest I had a blown rear light bulb. Upon inspection, I discovered I have no tail light NOR brake light. The fact that both lights are out suggests to me a problem other than light bulbs. I might be wrong, I hope I'm wrong!, but I might be right. What do you think the likely culprit is? This CANBUS stuff is a mystery to me. Were this an older bike, I'd look to replace a fuse, but there are no fuses on this bike. Am I looking at a big bill for repair? Link to comment
dirtrider Posted October 15, 2019 Share Posted October 15, 2019 2 hours ago, beemerman2k said: My console lit up to suggest I had a blown rear light bulb. Upon inspection, I discovered I have no tail light NOR brake light. The fact that both lights are out suggests to me a problem other than light bulbs. I might be wrong, I hope I'm wrong!, but I might be right. What do you think the likely culprit is? This CANBUS stuff is a mystery to me. Were this an older bike, I'd look to replace a fuse, but there are no fuses on this bike. Am I looking at a big bill for repair? Afternoon beemerman2k Definitely check the rear bulbs (I don't have a K1300 manual handy) but I believe that your bike has 2 tail/brake light bulbs. They are single filament so the same bulbs are both for brake & tail light. Link to comment
beemerman2k Posted October 15, 2019 Author Share Posted October 15, 2019 Ahhh, thank you! Link to comment
dirtrider Posted October 15, 2019 Share Posted October 15, 2019 25 minutes ago, TF1200RT said: Mine has two bulbs, dual filament. Evening TF1200RT Are you sure on the dual filament as my BMW parts book shows the 2009 K 1300GT uses (2) single filament bulbs. Link to comment
TF1200RT Posted October 16, 2019 Share Posted October 16, 2019 I saw that too. I went outside and turned on the ignition and looked at the tail lights. Two lit up and when I stepped on the brake, the same two lit. I guess the CANBUS must be regulating the current. Bulbs show as P21W / 12V / 21W. Link to comment
dirtrider Posted October 16, 2019 Share Posted October 16, 2019 57 minutes ago, TF1200RT said: I saw that too. I went outside and turned on the ignition and looked at the tail lights. Two lit up and when I stepped on the brake, the same two lit. I guess the CANBUS must be regulating the current. Bulbs show as P21W / 12V / 21W. Morning TF1200RT Yes, both the current & voltage to the rear bulbs are being P/W regulated but not by the CanBus. Both the CAN (Controller Area Network) and the CanBus, (Bus that allows the controllers to talk to each other) have no ability to regulate anything (they just allow communication between onboard controller modules). The actual current/voltage regulation & switching is being done by the chassis controller for the rear light control. Now when the bulb-out dash light illuminates then 'that' info is going out over the CAN via the CanBus so the dash controller knows when to turn the bulb-out light on. Link to comment
TF1200RT Posted October 16, 2019 Share Posted October 16, 2019 7 hours ago, dirtrider said: Morning TF1200RT Yes, both the current & voltage to the rear bulbs are being P/W regulated but not by the CanBus. I wrote that in an early morning fog. Link to comment
Sanford Posted May 18, 2020 Share Posted May 18, 2020 Hello Beemerman.. Have you resolved this tail and brakelight problem as I am experiencing the exact prob, on my 2010 k 1300 gt. Bulbs are all good. Yellow light on instrument panel along with rear light out indicator. Thanks Sanford Link to comment
beemerman2k Posted June 8, 2020 Author Share Posted June 8, 2020 Update: MICE! Mice are getting under the bodywork and chewing on some wiring. That's what's causing my taillight issues. The bulbs are fine, the electronics are fine, the mice are causing problems. Link to comment
