BeemerBerg Posted October 12, 2019 Share Posted October 12, 2019 My ‘16 RTW was ‘overcome by gravity’ the other day. Anyone know the Duplicolor (or other brand) number of the engine/valve cover paint? Link to comment
Corazon de Pollo Posted October 12, 2019 Share Posted October 12, 2019 Try looking up "963 Granite Grey Metallic Matt": it was the one used on 2016 R1200GS engines and wheels. I am not 100% sure it's a perfect match for an RT but it may be worth checking out. Link to comment
TEWKS Posted October 12, 2019 Share Posted October 12, 2019 Another option is this ... https://www.revzilla.com/motorcycle/rg-racing-carbon-fiber-head-cover-bmw-r1200gs-gsa-r1200r-rs-rt?gclsrc=aw.ds&&gclid=EAIaIQobChMIiJu8pLWX5QIVkIjICh0RSgDFEAQYASABEgJA_PD_BwE Edit... If this idea interests you, make sure you do a dry fit before applying the silicone glue. The right side fit perfectly on mine, the left not so much. The cut along the plug cap was off. Link to comment
strataj Posted October 12, 2019 Share Posted October 12, 2019 3 hours ago, TEWKS said: Another option is this ... https://www.revzilla.com/motorcycle/rg-racing-carbon-fiber-head-cover-bmw-r1200gs-gsa-r1200r-rs-rt?gclsrc=aw.ds&&gclid=EAIaIQobChMIiJu8pLWX5QIVkIjICh0RSgDFEAQYASABEgJA_PD_BwE Those are real nice. If you still wish to paint https://www.autogeek.net/1z-einszett-silver-wheel-paint.html Link to comment
Tri750 Posted October 15, 2019 Share Posted October 15, 2019 At the dealership I worked at , we used the Wurth products for many things. They make a BMW wheel paint that is very nice to use . it appears to be the timeless color used over the years. The brand above suggests Wurth clear but here is the Wurth paint and clear. https://www.autogeek.net/wurth-1z-combo.html A very very close match we found was Krylon Dull Aluminun . Lots of metal and you can use Krylon clear if you want to gloss it up. Test on something to be sure but on the early stuff, 1100-1150, it was mighty good . not touch up, doing the whole rocker cover . Check it out, ymmv Link to comment
JamesW Posted October 15, 2019 Share Posted October 15, 2019 Dupli-Color Engine Enamel with Ceramic spray paint DE1615. The color is aluminum and I purchased it at the local NAPA store also available from Amazon. It withstands heat up to 500F and is specifically used for engine blocks and is a perfect match. I used some flat files and wet/dry sand paper to completely remove all scratches. Duplicolor also has a high temperature clear coat that can be applied over the aluminum paint which I didn't bother with just two coats of the aluminum color paint and it looks perfect. Then I invested in some case guards from National Motorcycle Parts which obviously I should have done sooner. I am assuming your valve covers are the same color as on my much older R1100. When I dropped it I also damaged the left turn signal which I was able to replace with new parts from Bob's BMW. Lucky no damage to the body work. Really nice to be able to buy new OEM parts for a 26 year old bike. Try doing that with a big 4 motorcycle. Easy to forget how well BMW supports their older products in comparison to other manufacturers. Link to comment
eddd Posted October 15, 2019 Share Posted October 15, 2019 Good suggestions above, but it is easy also easy to find a close match at the auto parts store. I fixed a few valve covers and found that you really can't tell the slight difference. Since you are not trying to match a continual part/panel, light angles and shadows make an exact match unnecessary. Link to comment
