RPG Posted October 7, 2019 Share Posted October 7, 2019 2004 RT, 108k. Just noticed my Oil Pressure light isn't illuminating with Ignition On. Does anyone have a diagram with bulb sizes, wattages for the dash indicator lights? I figure I'll replace them all while I'm in there. thanks, RPG Link to comment
dirtrider Posted October 7, 2019 Share Posted October 7, 2019 1 hour ago, RPG said: 2004 RT, 108k. Just noticed my Oil Pressure light isn't illuminating with Ignition On. Does anyone have a diagram with bulb sizes, wattages for the dash indicator lights? I figure I'll replace them all while I'm in there. thanks, RPG Afternoon Rick First check the simple things, make sure that the wire is plugged into the Oil Pressure Switch on the L/H side of the engine block. Oil indicator bulb is a 12V 3W __ BMW P/N 62 14 2 306 126 The Generator bulb is a 1.7 watt but it should be replaced with the above 3 watt as that brings the alternator on-line earlier after engine starting (gives a quicker smooth cold idle) Link to comment
RPG Posted October 7, 2019 Author Share Posted October 7, 2019 7 minutes ago, dirtrider said: Afternoon Rick First check the simple things, make sure that the wire is plugged into the Oil Pressure Switch on the L/H side of the engine block. Oil indicator bulb is a 12V 3W __ BMW P/N 62 14 2 306 126 will do D.R. And thank You! Link to comment
