gep2show Posted April 22, 2006 Share Posted April 22, 2006 I have a 2002 RT that makes a loud rattling sound inside the exaust pipe when I rev tne motor.It's as if there is something loose internally. Any thoughts....Thanks Link to comment
Paul_Burkett Posted April 22, 2006 Share Posted April 22, 2006 Where is the rattle, in the exhaust its self, the cat converter, or the muffler? When do you here it, start low revs, high revs, under load in high gear at low speeds? Also, please fill in your profile, we are not going to stalk you or anything. Link to comment
redryder Posted April 23, 2006 Share Posted April 23, 2006 I have a 2002 RT that makes a loud rattling sound inside the exaust pipe when I rev tne motor.It's as if there is something loose internally. Any thoughts....Thanks I'm no BMW tech, but on a car exhaust, that's a good sign that the Cat is going bad. Link to comment
gep2show Posted April 23, 2006 Author Share Posted April 23, 2006 The rattle starts at high revs in neutral or while riding in any gear...I have not pinpointed the exact location of the sound...Thanks Link to comment
gep2show Posted April 23, 2006 Author Share Posted April 23, 2006 I had a cat go on an old Trans Am back in the 80s.That just might be the culprit.Can the cat be replaced by a "test" pipe without any problems as far as inspections go? Thanks Link to comment
Paul_Burkett Posted April 23, 2006 Share Posted April 23, 2006 Yes, you can replace the cat and not have any problems with inspections, because you will be saving the cat for re-installation for inspections of when you sell it. Link to comment
Bart Anderson Posted April 24, 2006 Share Posted April 24, 2006 Are you sure it's internal? I had a gnarly rattle last year...the rubber mounting bushing at the rear muffler hangar had worked its way out and disappeared. #2 in the diagram below...$2 fix. Link to comment
2wheelterry Posted April 24, 2006 Share Posted April 24, 2006 I have always been sucessful replicating those pesky exhaust rattles by banging/knocking on the various exhaust components. Give it a try if you haven't. Link to comment
