wardyRT Posted April 21, 2006 Share Posted April 21, 2006 I recently had the misfortune of sliding my beautiful RT down the tarmac. After fixing the more obvious cosmetic and structural damage, I noticed that I could wiggle the handlebars up and down about 1/16". After looking at them more thoroughly it appears the bearing in the top fork clamp is kaput. I'm wondering if anyone else has taken one of these out? Even using a breaker bar, the bolt holding everything together seems stuck. Any thoughts? I don't want to do my normal "haul on it til it breaks" routine if there's an easier way. Thanks in advance...GW Link to comment
Timmer Posted April 21, 2006 Share Posted April 21, 2006 I'm not certain which bolt/nut you're talking about, but I suspect it has Loctite on it and probably needs to be heated with a heat gun before you can break it loose. Don't melt the cables and wiring when you do this! Tim Link to comment
wardyRT Posted April 22, 2006 Author Share Posted April 22, 2006 The RT shop manual I have does indeed say "heat to 120 degrees C. to release. Thanks fer the help. When all else fails... Link to comment
