grusgets Posted September 6, 2019 Share Posted September 6, 2019 Hello! I'm starting this new thread, with the hope to find a fix for my bike's poor idle and low speed jerkiness. I've made a few posts on another thread, but after dirtrider's recommendation, I'm making a new start here. Bike in question is a 2004, R1200GS, first generation of hexheads, with servos,, made for the European market (just in case it makes any difference), with 66.000kms on the clock. I think it was introduced in 2005 in the US. So, long story short, years ago, I moved my throttle body idle screws from their original position, with no obvious reason and as a result, idle and above idle speed became messy. Here are some info about what is changed, repaired, modified or eliminated. The bike runs on a modified BMSK. Both ignition and fueling are remapped. Rev limiter is moved higher. Remapping took place from distance. I mailed my BMSK, and it was sent back modified. The bike was never dynoed. Headers and muffler are changed to aftermarket Remus. Headers are of larger diameter, with no connection tube. Muffler has its silencer installed. There is NO cat. Air filter is K&N. Air box and airbox snorkel are NOT modified. L/H side chain tensioner is replaced with the "better design" one. All sensors are installed and they report back. Engine runs on 10w-60 fully synthetic oil. Spark plugs are NGK iridiums, 15,000kilometers/4 years old. Valves were done on May, 2,000kms ago. Rocker arm end play is towards the lower end but not minimal. Both lambda sensors are installed and presumably work normally. Tuning guy assured me he did not eliminate them. Please note that remapping of the BMSK was performed after I moved the idle screws, and it did not make idling worse. The same guy said that his mod will not affect idling. He was not aware of my messy idle screws, and I never told him. I didn't want to complicate things. Bike is strong and I am satisfied with the modifications done. It is gentle with gas and oil consumption is minimal. Although strong however, engine is noisy, and I cant say that it runs great either. I can't even remember it being "smooth like butter" or "purring like a kitten" (borrowed expressions), perhaps because of me messing with the idle screws. I really don't know. Maybe an unbalanced condition, will promote strange noises. For example at very hot idle, I will hear both timing chains slapping on their guides. At steady throttle, and at "some" rpms, resonance noises will emerge from the valve train. Also, with engine at low rpm and operating temperature, and ONLY under load, it will rattle, from its center. It will do it more intensively when leaving from a traffic light. With a pillion it will be even worse. I'm just trying to give an overall picture of the engine here. Concerning the throttle bodies, the bike will always run better, but not perfect, after a cold start and during the first couple of minutes. It will change gears more quietly, it will idle sweeter, more powerfully, and it will not rattle. As it warms up, things will eventually get worse, noisier and clankier. Idle will "loosen", and throttle response will decrease. When leaving from a stop, I always have a feeling that something slightly holds me back (wheels turn freely of course). The worst is crawling with 1st or 2nd gear in the traffic with a pillion, at idle and above idle speed. Really terrible. I always slip the clutch and try to keep the speed and the rpms up. Sometimes it really sounds like a small diesel engine. And if I let it cool for, say 15-20 minutes, it is a totally different bike. Crazy! In my other thread, Dirtrider had made me some questions which I think should be posted here as well for reference. The lines in brackets were added later. Are the o2 sensors still active & being used for fueling control? Yes, they are still there and active, as far as I am told. What is your current hot engine base idle RPM? Can't be sure about this. Numbers play around 1100 and 1200. [The numbers I am referring to, are displayed on the screen of my phone through the Motoscan app] Have the base idle screws on the throttle bodies ever been moved? Definitely yes. Is the blue TB idle screw indexing paint still intact? Blue paint is not visible. Not at all! What are your cold start stepper counts? I don't remember unfortunately. Around 120 I think. I can have that piece of information soon. [I checked this today morning. From cold start at 28.5C, stepper counts were 144, on both sides. Soon after, with 39C, steps dropped to 139] Do the stepper counts ever go independent? Or are they always reading the exact same counts? They always show the same reading. Always! [They show the same count when they are connected. If I unplug one, its number will freeze, and the other stepper will continue to move around] Are the throttle cables tight & not allowing the TB throttle shaft arms to firmly sit on the base idle screws? No, both throttle cables are pretty loose. I would really appreciate any help. George Link to comment
dirtrider Posted September 6, 2019 Share Posted September 6, 2019 Morning grusgets Thanks for starting a new thread, this way we can keep your thread going & separate. I'm trying to understand your problem (what you posted above sure helps). But I'm still having a difficult time understanding the problem's root-cause issue. We might have to poke around on it a little until we have a good understanding. (I wish I could ride that bike as that would allow an instant understanding) The hot engine stepper counts are a bit high but I don't think this has anything to do with your issue. It doesn't sound like your base idle screws are set correctly but that is an idle thing only & probably isn't your rough ride-off problem (or at least not the main contributor). The other thing making this more difficult is that you have a very early 1200 bike (I'm sure your early 1200 has no fueling computer updates so we don't know if your problem was addressed in later BMS-KP firmware updates. In just reading your above, the first thing that came to my mind is a lower stick coil (or coils) is not functioning correctly. The 1200 will run OK at speed with a lower stick coil not working but they idle badly & the launch from a stop is usually rough & jerky with sometimes internal engine rattles. So lets start off with 3 things___ Can you see if the engine will run on JUST the lower spark plugs (It won't idle without adding throttle but should run on the lowers only (just unplug the upper coils then see if it will run on the lowers only)-- If it doesn't sound right or has problems running then (carefully) feel the front exhaust pipes to see if BOTH are hot & about the same temperature. Second thing__ (with all 4 coils operating again) -- Your early 1200 should have (2) cylinder head temperature sensors (one on each cyl head). Can you see (in the GS-911 data if both are close to same temperature with engine running for a while & idling (post each side temperature here? ). Have you done a proper TPS re-learn? If so what is your hot idle TPS GS-911 reading? If you haven't done a TPS re-learn then do that BEFORE taking the GS-911 TPS data. (if you don't know how to do a TPS re-learn then let me know & I will post the procedure) Link to comment
grusgets Posted September 6, 2019 Author Share Posted September 6, 2019 2 hours ago, dirtrider said: Can you see if the engine will run on JUST the lower spark plugs (It won't idle without adding throttle but should run on the lowers only (just unplug the upper coils then see if it will run on the lowers only)-- If it doesn't sound right or has problems running then (carefully) feel the front exhaust pipes to see if BOTH are hot & about the same temperature. I tried that and the bike idles and revs exactly the same with the upper plugs either connected or disconnected. Disconnecting the upper plugs will make no difference. I did not ride it. I tested it on its center stand. 2 hours ago, dirtrider said: Second thing__ (with all 4 coils operating again) -- Your early 1200 should have (2) cylinder head temperature sensors (one on each cyl head). Can you see (in the GS-911 data if both are close to same temperature with engine running for a while & idling (post each side temperature here? ). Yes it does have two temp sensors indeed, one on each side. And luckily enough, today they are spot on. A week ago i can remember seeing them at least 6 degrees celsius apart. But i have moved the idle screws since then. 2 hours ago, dirtrider said: Have you done a proper TPS re-learn? If so what is your hot idle TPS GS-911 reading? If you haven't done a TPS re-learn then do that BEFORE taking the GS-911 TPS data. (if you don't know how to do a TPS re-learn then let me know & I will post the procedure) Yes I have. Every time I move the L/H idle screw or charge my battery or store for winter, I do a tps re-learn. I don't understand what GS-911 TPS data is. I don't have a GS-911. I use the android app called Motoscan. Link to comment
dirtrider Posted September 6, 2019 Share Posted September 6, 2019 Morning grusgets As a rule I like to see the cylinder head temp readings be slightly different. They almost never match exactly so when they read the EXACT same it usually points to the BMS-KP using one side reading for both sides (not a big deal as on later 1200 bikes BMW eliminated one cyl heed temp sensor & used just one side to feed temp to both sides). Or, it could be telling us that one side is not working correctly so the BMS-KP substituted the working side input for the non working side. (keep an eye on the cylinder had temps to see if they vary slightly side to side) I haven't ever used Motoscan myself but have worked with a couple of riders that were using one. It complicated things as some of the data they got from the Motoscan didn't match what I expected to see from a GS-911 or dealer computer. I guess if that is what you have then we will have to work with it. I'm still not exactly sure what we are dealing with here as you have the idle screw/idle discrepancy with linked stepper counts (this is one issue to deal with) But then you also have the launch problem & engine rattle issue. I'm not sure that your idle problem is linked to your launch/rattle problem. Let me think on this for a bit, I will post more later. Link to comment
dirtrider Posted September 6, 2019 Share Posted September 6, 2019 Afternoon grusgets More thoughts____ What does your Motoscan show for TPS position data? Does it have a TPS setting option? Messing with the L/H base idle screw can change the TPS base position vs idle/above idle lift off. Link to comment
grusgets Posted September 6, 2019 Author Share Posted September 6, 2019 It only has one option, under analog outputs, which is called "relative throttle angle". It will go from 0,00% to 100% with engine either on or off. On idle it is showing 0,00%. 1 hour ago, dirtrider said: Messing with the L/H base idle screw can change the TPS base position vs idle/above idle lift off. I know, but I have already messed with this screw. It can't get any worse, right? Link to comment
Ponch Posted September 7, 2019 Share Posted September 7, 2019 What's the total mileage on the bike? Just curious. Link to comment
grusgets Posted September 7, 2019 Author Share Posted September 7, 2019 4 hours ago, Ponch said: What's the total mileage on the bike? Just curious. 66,000kms Link to comment
dirtrider Posted September 7, 2019 Share Posted September 7, 2019 18 hours ago, grusgets said: It only has one option, under analog outputs, which is called "relative throttle angle". It will go from 0,00% to 100% with engine either on or off. On idle it is showing 0,00%. I know, but I have already messed with this screw. It can't get any worse, right? Morning grusgets Again, I don't know how the Motoscan reads the TPS info but the full sweep of 0-100% sounds like you are getting full TPS authority. (I guess we have to assume that your TPS is OK unless we see something later that points back to it). We still have to verify that the lower spark plugs are operating correctly (very important for proper idle, just above idle, & launch). Once up to mid engine RPM & above then the lower spark plugs are pretty well out of the picture & make little to no difference. Link to comment
grusgets Posted September 7, 2019 Author Share Posted September 7, 2019 Should I try again to set my idle screws to a new position and see what happens? I may have a way to roughly bench calibrate them with some vacuum and a homemade manometer. If I get them closer to the "correct" position, and see that rattle or jerkiness of the motor decreases, it will be a good sign. If not, I can try setting them to another position, and then again to another, and so on. Link to comment
Ponch Posted September 8, 2019 Share Posted September 8, 2019 6 hours ago, grusgets said: Should I try again to set my idle screws to a new position and see what happens? I may have a way to roughly bench calibrate them with some vacuum and a homemade manometer. If I get them closer to the "correct" position, and see that rattle or jerkiness of the motor decreases, it will be a good sign. If not, I can try setting them to another position, and then again to another, and so on. In the original TB pulley replacement post, dirtrider has procedure for setting the screws. Link to comment
dirtrider Posted September 8, 2019 Share Posted September 8, 2019 16 hours ago, grusgets said: Should I try again to set my idle screws to a new position and see what happens? I may have a way to roughly bench calibrate them with some vacuum and a homemade manometer. If I get them closer to the "correct" position, and see that rattle or jerkiness of the motor decreases, it will be a good sign. If not, I can try setting them to another position, and then again to another, and so on. Morning grusgets Eventually you will probably want to do that BUT if you keep trying to get ahead of things & jump around then I am wasting my time trying to help you. WILL THAT ENGINE RUN ON JUST THE LOWER SPARK PLUGS??????????????????????????????????-- this is the next thing to verify. Before you move anything on the base idle screws we need the hot engine curb idle stepper counts as well as the hot engine side to side manometer column height differences, plus we need to know if the engine is operating in closed loop at the time that you are obtaining the above. (the above 3 things need to be obtained at the same time & same engine run cycle) If you start jumping around trying things/turning things then we loose the base line & have no idea on where we are at or what is happening (didn't randomly turning/adjusting things get you into this mess?) Link to comment
grusgets Posted September 8, 2019 Author Share Posted September 8, 2019 Hello dirtrider. Thank you for your answer. The engine will idle and run with just the lower spark plugs connected, as I have written a few posts earlier. Will try later to upload pictures of the manometer height difference and the stepper count on hot idle. As for the "engine closed loop", are you referring to the O2 sensor closed loop or something else? Thank you Link to comment
dirtrider Posted September 8, 2019 Share Posted September 8, 2019 1 hour ago, grusgets said: Hello dirtrider. Thank you for your answer. The engine will idle and run with just the lower spark plugs connected, as I have written a few posts earlier. Will try later to upload pictures of the manometer height difference and the stepper count on hot idle. As for the "engine closed loop", are you referring to the O2 sensor closed loop or something else? Thank you Morning grusgets OK, I somehow missed your response above about running OK on the lower plugs, (that eliminates that) Yes, on the o2 sensors & closed loop. If your Motoscan has a "lambda control factor" column see what that is saying (like a 1 or a larger number). Best way to see what is happening (closed loop wise) is to watch the lambda (o2 sensor) output voltages as the engine is running. If you see the numbers toggling above & below .500 volts (like 340.1 / 620.3 / 200.8 / 766.4 / 470.7 / 689.6 etc then that means the lambda sensors are controlling the fueling on that cylinder. Link to comment
grusgets Posted September 9, 2019 Author Share Posted September 9, 2019 Hello dirtrider. I'm back again with some fresh feedback. Fortunatelly, Motoscan will show what lambdas are doing. It has a line called "oxygen-sensor control". At hot idle it says "active". if I accelerate the engine it will switch to "not active", the same during deceleration. When rpm stabilize to idle, it will say again "active". I didn't have the opportunity to check it at cold idle. When i started taking my measurements, engine was already at operating temperature. I had to ride to go to my garage. Lambda voltage fluctuated between 0.2v and 0.8v, however one lambda was faster enough than the other. I used torque automotive app to obtain the lambda voltages, because Motoscan was not very straight forward with these numbers. I toggled between the apps in the same engine cycle. Vacuum height difference began at 4", and increased to 5.5" as engine temp kept rising. I didn't measure the internal diameter of the clear hose, but it will fit firmly on the TB nipples if this helps. I took three screenshots with 2 minutes interval, of the stepper count and the cylinder head temp. You can use temperature as the sequence reference. However, during the time i spent to my garage, there are three other things that i noticed. 1) Knock sensor reference voltages had a constant discrepancy of around one voltage during the whole time I had Motoscan connected. 2) When i hot-started the engine for a second time, oxygen sensor control was constantly inactive for a minute or so. Then it toggled to active, without me doing anything. 3) The last time that I turned the ignition on, without starting the engine, just before leaving for home (with the Motoscan still connected, and my phone in sight, inside a clear pocket of my tank bag), I'd like to draw your attention here, I observed that the stepper count was 194 at both sides, instead of 204, as it always is. I cycled the ignition off and on, and again the steppers showed a count of 194. I had my both hands on the handlebars at the moment so I spontaneously turned the throttle, and to my surprise i heard the steppers moving. With zero throttle they showed 194, and with tiny throttle opening they jumped to 204. The bike acted like this the whole day, yesterday. Watch the video. What you can't see is my hand opening the throttle. You will hear them, move to 204 and then back to 194, two times. At the same time I open and close the throttle two times. Honestly, I have never noticed this thing on my bike for years! 20190908_184611_1.mp4 20190908_184611_1.mp4 Thank you! George Link to comment
dirtrider Posted September 9, 2019 Share Posted September 9, 2019 1 hour ago, grusgets said: Hello dirtrider. I'm back again with some fresh feedback. Fortunatelly, Motoscan will show what lambdas are doing. It has a line called "oxygen-sensor control". At hot idle it says "active". if I accelerate the engine it will switch to "not active", the same during deceleration. When rpm stabilize to idle, it will say again "active". I didn't have the opportunity to check it at cold idle. When i started taking my measurements, engine was already at operating temperature. I had to ride to go to my garage. Lambda voltage fluctuated between 0.2v and 0.8v, however one lambda was faster enough than the other. I used torque automotive app to obtain the lambda voltages, because Motoscan was not very straight forward with these numbers. I toggled between the apps in the same engine cycle. Vacuum height difference began at 4", and increased to 5.5" as engine temp kept rising. I didn't measure the internal diameter of the clear hose, but it will fit firmly on the TB nipples if this helps. I took three screenshots with 2 minutes interval, of the stepper count and the cylinder head temp. You can use temperature as the sequence reference. However, during the time i spent to my garage, there are three other things that i noticed. 1) Knock sensor reference voltages had a constant discrepancy of around one voltage during the whole time I had Motoscan connected. 2) When i hot-started the engine for a second time, oxygen sensor control was constantly inactive for a minute or so. Then it toggled to active, without me doing anything. 3) The last time that I turned the ignition on, without starting the engine, just before leaving for home (with the Motoscan still connected, and my phone in sight, inside a clear pocket of my tank bag), I'd like to draw your attention here, I observed that the stepper count was 194 at both sides, instead of 204, as it always is. I cycled the ignition off and on, and again the steppers showed a count of 194. I had my both hands on the handlebars at the moment so I spontaneously turned the throttle, and to my surprise i heard the steppers moving. With zero throttle they showed 194, and with tiny throttle opening they jumped to 204. The bike acted like this the whole day, yesterday. Watch the video. What you can't see is my hand opening the throttle. You will hear them, move to 204 and then back to 194, two times. At the same time I open and close the throttle two times. Honestly, I'd never noticed this thing on my bike for years! 20190908_184611_1.mp4 6.93 MB · 0 downloads 20190908_184611_1.mp4 6.93 MB · 0 downloads Thank you! George Afternoon George This is both good news & bad news. The good news is that your liquid column height is well within reason (under 200mm side to side variance is good & under 250mm is OK. You do seem to be going into closed loop with o2 sensors toggling across the center value (so fueling control is working). Stepper counts are just a bit high but should work where they are at (they are not running out of travel). The steppers following the throttle opening/closing is normal as that is an anti-stall feature for a sudden dropped throttle. Your steppers are not going independent & your cylinder head temperatures are the same (this is something we need to figure out). On the steppers not going independent, once you reach closed loop, is a puzzler (you do have a very early 1200 bike), way earlier than I have ever worked with so possibly at that BMS-KP firmware iteration that wasn't available yet. (my guess is that it had independent stepper control but I have no way to verify that other than a guess). On the cylinder head temp readings being identical?-- THIS is also a puzzler-- Some possibilities on this. With you having a re-programmed BMS-KP it's possible it was somehow updated to use the later firmware. Later firmware ONLY used one side cylinder head temp reading. If only one cyl head temp sensor is being used for calculations then you WILL (always) have matching cylinder head temperatures. (this is something to look into) This also m-i-g-h-t factor into the steppers not going independent as on the early 1200 bikes I have suspected that the cylinder head temperatures were use as part of the stepper control feed-back. (never proved just guessed at). I also don't know what you have going on with the knock sensors__ It's possible that you have a sensor or sensor(s) issue, or very possible the pizo knock sensors are picking up (& reacting to) all that engine noise that you are hearing. I wouldn't adjust anything on the base idle screws just yet as the problem really isn't pointing in that direction. You might try disconnecting one cylinder temperature sensor, then reconnecting & disconnecting the other cylinder temperature sensor to see if you can define IF the fueling computer is using JUST one for both sides or using both (as the early 1200 bikes should be). You might also try running & riding the bike with both knock sensors disconnected (you need to try & understand WHY they are doing what they are doing). This is getting more & more difficult to understand over the internet-- Having a very very early European 1200 sample bike, having a modified BMS-KP, not using a GS-911, doing it over the internet without hearing or riding the bike is making diagnosing a difficult problem extremely difficult. We'll keep poking along as maybe we will uncover something____ Link to comment
grusgets Posted September 12, 2019 Author Share Posted September 12, 2019 Hello dirtrider. I will try to talk to the tuning guy and see if tells me anything that could help. Question: Is it ok if I temporarilly install on the bike another unmodified BMSK for testing purposes? Any possible problems with immobilizer, ZFE or KOMBI? Thanks Link to comment
dirtrider Posted September 12, 2019 Share Posted September 12, 2019 3 hours ago, grusgets said: Hello dirtrider. I will try to talk to the tuning guy and see if tells me anything that could help. Question: Is it ok if I temporarilly install on the bike another unmodified BMSK for testing purposes? Any possible problems with immobilizer, ZFE or KOMBI? Thanks Morning grusgets On installing a different BMS-KP unit, I just don't know. The BMS-KP is a coded part (coded to the motorcycle vin). I'm really not sure if it work a little, work at all, or even allow basic functions. It might not even recognize your present coded key as they usually need EWS programming . As a rule when a new BMS-KP is installed it needs a CIP (coding, individualisation and programming) done. I guess you can try to install the new (used) one, then try to address any problems that show up (might not even recognize the key or start though). Link to comment
Ponch Posted September 13, 2019 Share Posted September 13, 2019 16 hours ago, dirtrider said: Morning grusgets On installing a different BMS-KP unit, I just don't know. The BMS-KP is a coded part (coded to the motorcycle vin). I'm really not sure if it work a little, work at all, or even allow basic functions. It might not even recognize your present coded key as they usually need EWS programming . As a rule when a new BMS-KP is installed it needs a CIP (coding, individualisation and programming) done. I guess you can try to install the new (used) one, then try to address any problems that show up (might not even recognize the key or start though). Is that only done with a dealer level tool or can the GS911 do it? Link to comment
dirtrider Posted September 13, 2019 Share Posted September 13, 2019 7 hours ago, Ponch said: Is that only done with a dealer level tool or can the GS911 do it? Morning Ponch As far as I know only a dealer computer. (this is on a U.S. bike). I'm not even sure if a dealer with the proper disk could program in a used (already coded BMS-KP). The OP here has a non U.S. bike that is a year earlier than I have any documentation on so I don't even show a BMS-KP available. 1 Link to comment
grusgets Posted September 20, 2019 Author Share Posted September 20, 2019 Hello, I have nothing new for the moment. I will try next week to ride the bike without knock sensors, understand what's going on with the temperature and fit another BSKM, and then I will report back. A question please. Are my steppers supposed to work independently from each other or not? Link to comment
dirtrider Posted September 20, 2019 Share Posted September 20, 2019 6 hours ago, grusgets said: Hello, I have nothing new for the moment. I will try next week to ride the bike without knock sensors, understand what's going on with the temperature and fit another BSKM, and then I will report back. A question please. Are my steppers supposed to work independently from each other or not? Morning grusgets Yes, no, maybe so-- how is that for an evasive answer? On the 1200 hexhead bikes that I have worked with the steppers are linked (go to same counts left & right) for cold start & for a while after engine start, then once the engine warms they then go independent & operate separately (un-linked). Problem is I haven't ever worked with a 2004, R1200GS (that is a VERY early released 1200 motorcycle), I assume that they also had independent stepper control but have nothing to verify that against. (with (2) cylinder head temperature sensors & (2) o2 sensors I would assume that the engine has independent stepper control, but this is more of a guess than a fact on the early 2004 1200). One of the problems on the BMW 1200 is that it uses simple 4 wire steppers so the steppers have no actual position feedback back to the BMS-KP (ie the BMS-KP only knows where the stepper pintle is at from where it was last commanded, not from actual pintle feedback position). If it (pintle) doesn't actually get to where it was commanded, or gets lost, then the BMS-KP has no idea where the stepper pintle actually is in relation to it's seat or to commanded counts. Link to comment
