Super Dave Posted September 2, 2019 Share Posted September 2, 2019 When hooking up an External Tach inductor lead from the left then right cylinder, I'm coming up with about twice the spark on the right. Examples, At idle - Left = 1100 & Right = 2200 RPM At 3k - Left = 3000 & Right = 6000 RPM Is that normal? I have a video, but it's too large to attach. Link to comment
dirtrider Posted September 2, 2019 Share Posted September 2, 2019 25 minutes ago, Super Dave said: When hooking up an External Tach inductor lead from the left then right cylinder, I'm coming up with about twice the spark on the right. Examples, At idle - Left = 1100 & Right = 2200 RPM At 3k - Left = 3000 & Right = 6000 RPM Is that normal? I have a video, but it's too large to attach. Afternoon Dave I presume that you are using your inductive pickup on the lower spark plug wires? If so then you might have to reverse the pickup direction on the R/H side (arrow pointing away from spark plug) as on the 1150 twin spark one side lower sparks positive polarity & the other side is reverse & sparks negative polarity. Also remember that the lower spark plugs fire at EVERY piston up so set your Tac to one spark per rev (or even 2 cycle setting) 1 Link to comment
Super Dave Posted September 2, 2019 Author Share Posted September 2, 2019 LOL !!! That Was It !! Nothing to see here, move along... LOL. Link to comment
