SteveS RT Posted August 26, 2019 Share Posted August 26, 2019 I've had my 2014 RT for a week now and dropped my front wheel off to get a new tire. While moving it around I hear a "chink" sound and find that both disks have some play in them. I can move each one, just a little, maybe 0.010" or less. is that normal? Other bikes i've had have been very solidly mounted. Steve Link to comment
dirtrider Posted August 26, 2019 Share Posted August 26, 2019 9 minutes ago, SteveS RT said: I've had my 2014 RT for a week now and dropped my front wheel off to get a new tire. While moving it around I hear a "chink" sound and find that both disks have some play in them. I can move each one, just a little, maybe 0.010" or less. is that normal? Other bikes i've had have been very solidly mounted. Steve Afternoon Steve That is pretty normal as your brake rotors are semi-floating so aren't solidly mounted to the wheel. Link to comment
SteveS RT Posted August 26, 2019 Author Share Posted August 26, 2019 Thanks, like i said i'm a bit new here. it is certainly a different animal than my last 2 FJRs. Link to comment
Cap Posted August 26, 2019 Share Posted August 26, 2019 46 minutes ago, dirtrider said: That is pretty normal as your brake rotors are semi-floating so aren't solidly mounted to the wheel. DR, if there were excessive play in the rotors, could that be the cause of the high-speed vibration? Cap Link to comment
SteveS RT Posted August 26, 2019 Author Share Posted August 26, 2019 I was wondering if it could be related.... but i'll have a new tires on the bike by this weekend. Link to comment
dirtrider Posted August 26, 2019 Share Posted August 26, 2019 1 hour ago, Cap said: DR, if there were excessive play in the rotors, could that be the cause of the high-speed vibration? Cap Afternoon Cap Possible, but the rotors should not be loose enough to run out far enough to cause issues (at least at speeds that a BMW can move at). Most if not all of the looseness or play should only be in the rotation direction. Link to comment
AndyS Posted August 27, 2019 Share Posted August 27, 2019 The disc movement should only be lateral, not rotational. So they should not induce vibration. Link to comment
