Kerry in Mpls Posted August 25, 2019 Share Posted August 25, 2019 I picked up a 2016 R1200GS earlier this year. Intent is to use it primarily as a road touring machine. I have put road tires on it for best performance for that purpose. However, in the future I might want to occasionally hit some unpaved fire roads etc. So I am considering buying a spare set of rims and putting more off-road oriented tires on them so I can swap rims/tires as needed. If I were to look for used GS rims, is there a range of years I should target to fit on my '16? Link to comment
TEWKS Posted August 26, 2019 Share Posted August 26, 2019 Not a 100% on this but think you'll need to stay with the Wethead rims. Which are the 2013s' through present on the GS, and 2014 through present on the GSA. If you're talking light off road, IMO an easier option is to find a more in the middle tire that will work on both street and dirt roads. You'll lose a little on both ends but sometimes those inviting dirt roads pop up out of nowhere. Link to comment
Kerry in Mpls Posted August 27, 2019 Author Share Posted August 27, 2019 17 hours ago, TEWKS said: Not a 100% on this but think you'll need to stay with the Wethead rims. Which are the 2013s' through present on the GS, and 2014 through present on the GSA. If you're talking light off road, IMO an easier option is to find a more in the middle tire that will work on both street and dirt roads. You'll lose a little on both ends but sometimes those inviting dirt roads pop up out of nowhere. Yeah, I agree that a multipurpose tire is probably most the practical solution. I just like to know my options, even the less practical ones. Thanks for the feedback. 1 Link to comment
Foot Posted August 28, 2019 Share Posted August 28, 2019 Wethead are wider than previous GS rims. The cost of the of a spare set of wheels ain't cheap. If you want to do a direct swap out, you need to consider the extra cost of brake rotors and sensor ring. Good 80/20 tire will get you what you need without giving handling. Alan Link to comment
Kerry in Mpls Posted September 2, 2019 Author Share Posted September 2, 2019 On 8/27/2019 at 8:41 PM, Foot said: Wethead are wider than previous GS rims. The cost of the of a spare set of wheels ain't cheap. If you want to do a direct swap out, you need to consider the extra cost of brake rotors and sensor ring. Good 80/20 tire will get you what you need without giving handling. Alan Good point on rotors and sensor ring. The cost really adds up. OK, I am convinced it is more practical to change tires maybe a bit more often, rather than have a second set of wheel/tire assemblies. Link to comment
