Miguel! Posted August 23, 2019 Share Posted August 23, 2019 I like many or us have a tinge of arthritis. For me its in the left thumb knuckle. The only thing I do in life that uses that knuckle in anyway that hurts it is pushing up on the horn button. Is there any way to reduce the push=up tension on the horn button? Thanks Miguel Link to comment
dirtrider Posted August 23, 2019 Share Posted August 23, 2019 2 minutes ago, Miguel! said: I like many or us have a tinge of arthritis. For me its in the left thumb knuckle. The only thing I do in life that uses that knuckle in anyway that hurts it is pushing up on the horn button. Is there any way to reduce the push=up tension on the horn button? Thanks Miguel Afternoon Miguel There probably is a way (there always is with enough effort & ingenuity). Easy way would be to add a 2nd horn button in a different location that is easier to use (simple N/O push button would probably work). Link to comment
Miguel! Posted August 23, 2019 Author Share Posted August 23, 2019 1 hour ago, dirtrider said: Afternoon Miguel There probably is a way (there always is with enough effort & ingenuity). Easy way would be to add a 2nd horn button in a different location that is easier to use (simple N/O push button would probably work). Thanks dirtrider. I thought of that but doing anything, I thought I'd check here first to see if there were any clever ideas lurking out there. Cheers. Miguel Link to comment
