LAF Posted September 21, 2019 Share Posted September 21, 2019 Thank you Terry for the "black and white" of oil discussions. I tested before on bikes and cars and it has been a while. I have used LM in the RT and GS exclusively. The test gives me good reason to go out to 7 or 8K on my oil. Now I know your UOA is not relevant to my bike but it does confirm my thoughts that any high end oil should go 8-10k with no issues. Heck you could go 5k change the filter and go 5K more and I believe in my heart the bike would not care one bit. What a UOA does it tells you if your bike may have issues. If you have high amounts of coolant, or gas, or silicates from poor air filtration or copper so it will tell you if a bearing or some other metal component is wearing faster then it should. Thank you for sharing and I will get mine done this time out to get a reference. I have used LM and been happy with the shifting of the bike so really that is the only thing I can tell from a oil in BMW bikes. It just likes some oils better then others. My 15 RT was notorious for it. My 17.5 GS I have no idea as other then factory fill it has had LM in it from 600 miles on. Also as a side note I use LM in my FD also. Link to comment
Paul De Posted September 21, 2019 Share Posted September 21, 2019 Agree with your understanding of over the counter additives being unapproved generally and specifically those that contain molybdenum. However, by starting the very next sentence with the word additionally, it expands BMW's position to not allow any molybdenum substances no mater where it would be introduced. Are we to simply ignore that second sentence? Link to comment
Dave_in_TX Posted September 21, 2019 Share Posted September 21, 2019 4 hours ago, Paul De said: Agree with your understanding of over the counter additives being unapproved generally and specifically those that contain molybdenum. However, by starting the very next sentence with the word additionally, it expands BMW's position to not allow any molybdenum substances no mater where it would be introduced. Are we to simply ignore that second sentence? If you're going to interpret the first sentence as referring to over the counter additives rather than taking it completely on "face value", why are you so quick to assume that the second sentence is referring to an oil's additive pack? Is BMW using some exotic metal that no other motorcycle manufacturer is using? The oil manufacturers have to take into consider the metals commonly used in engines their oil is intended to be used in. I'd be willing to bet that the BMW oil actually has some form of soluble moly in it but without an oil analysis, we can't know. Link to comment
Dave_in_TX Posted September 21, 2019 Share Posted September 21, 2019 Found this at https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4117020/bmw-advantec-pro-15w50-motorcyle-oil : " very interesting seeing that my bmw manual says NO moly additives!! not a lot but 155 ppm, many motorcycle oils use none! being on this forum you prolly realise that semi-syn is quite the rip-off aka polaris semi-syn. there being no laws as to the amount of synthetic in the blend, prolly group III "synthetic" in this case from GTL technology aka purebase pennzoil platinum which may be better than the highly refined CRUDE also classed as group III. at $14.50 a qt i went shopping + found Valvoline "fully synthetic" motorcycle oil meets the SJ/JASO MA2 spec for $8.50 a qt @ wallys. its surely a group III synthetic + not a group IV or V base oil at that price + being all group III may very well be better than the $14.50 BMW ADVANTEC PRO 15-50 spec'd for us!! " This is regarding a VOA of the Advantec 15W50 so it's possible that the additives are different for the 5W40. Link to comment
kioolt Posted September 21, 2019 Share Posted September 21, 2019 Here' an interesting article on oil. http://www.calsci.com/motorcycleinfo/Oils1.html Link to comment
Dave_in_TX Posted September 21, 2019 Share Posted September 21, 2019 I only see the analysis for Molbil 1. On 9/17/2019 at 7:14 AM, realshelby said: Oil threads are often loathed. Partly due to posts saying "my oil is best, it is what YOU should be using" attitudes. Very few facts are in play. Well, here are some facts. I am sure there will be someone post that Blackstone labs can't do this or that, or that they are not accurate or may be biased. I have no response to that in this post. This oil report analysis is for my 2014 BMW R 1200 RT. Look for the line that says "Sample Date". Sample date of 9/1/2019 is the most recent. Castrol Racing 4T 10-40 Sample date of 6/16/2019 was Liqui-Moly 5-40 full synthetic Sample date of 11/6/2016 is the OLD formula Shell Rotella T-6 5-40 The samples of liqui-moly and Castrol could not be more equal. Both with about the same miles. Both used on one 4000+ mile trip, one 2500+ mile trip and a little local riding. I switched to the Castrol 10-40 hoping it would shift better. It did NOT shift as well as the other oils! Not a good feel at all. I also wondered if the 10-40 viscosity might show less shearing. It also doesn't quite measure up to the Liqui-Moly in other ways. Liqui-Moly is in the bike again, and shifting is back to normal. Which is pretty good really. Link to comment
92Merc Posted September 24, 2019 Share Posted September 24, 2019 I thought I would reach out to Liquid Moly, just to see what they have to say. This is their response: Dear Dale,thank you very much for contacting us and your interest in our LIQUI MOLY products.BMW Motorbike prohibits in its service instructions the use of Molybenum Disulfide (MoS2) based additives in the engine oil. The reason is - according to BMW- that under certain circumstances coatings in the engine can be peeled off. Neither LIQUI MOLY or other contacts in the lubricant business have observed the peel effeffect of any coating in an BMW Motorbike engines, yet.On the BMW Motorbike Days 2019 in Garmisch Patenkirchen non of the engineers of BMW Motorbike could answer the question of a participant which coating exactly may peel off...We have inhouse experience with R1200 and R1250 engines, with a 3% treatrate of LIQUI MOLY Motorbike Oil Additive for more than 80.000 kms / 50.000 miles now without any issue. Indeed, we observe a smooth running of the engine and also see no negative effekt on the wet clutch. Further none of our LIQUI MOLY Motorbike 4T oils do contain MoS2 - we just offer it as additional treatment.We hope we could help you with our information. Should you have further questions regarding our products we would be very pleased to get contacted from you again. Freundliche Grüße / Best regards i. A. Steffen NiemietzAnwendungstechniker application engineer F & E / Anwendungstechnik Phone: +49 731 1420-658Mobil: +49 162 2815064Fax: +49 731 1420-44658steffen.niemietz@liqui-moly.de LIQUI MOLY GmbHJerg-Wieland-Straße 4 | 89081 Ulm | GERMANY www.liqui-moly.de Link to comment
Paul De Posted September 25, 2019 Share Posted September 25, 2019 That Liqui Moly response is interesting. Direct and absent of the typical corporate weasel words on their position. Link to comment
longjohn Posted September 25, 2019 Share Posted September 25, 2019 On 9/17/2019 at 10:30 AM, longjohn said: Blackstone kit ordered. Blackstone kit sent back w/oil. Link to comment
Paul De Posted September 25, 2019 Share Posted September 25, 2019 Did I miss the post. Did anyone already have a test done on BMW Advantec Ultimate 5W-40, fresh or otherwise? We would put a bow on this thing with that info. Link to comment
longjohn Posted September 27, 2019 Share Posted September 27, 2019 On 9/25/2019 at 7:05 AM, Paul De said: Did I miss the post. Did anyone already have a test done on BMW Advantec Ultimate 5W-40, fresh or otherwise? We would put a bow on this thing with that info. It’s a comin’. By the time I get back off the road there should be an email for me. Link to comment
Endobob Posted October 1, 2019 Share Posted October 1, 2019 On 9/26/2019 at 10:58 PM, longjohn said: It’s a comin’. By the time I get back off the road there should be an email for me. Look forward to the report! I am slightly overdue for my next oil change. I bought the Beemer Boneyard 4L jug of LiquiMoly a while ago for this next oil change. However after reading through this post I have been considering purchasing the BMW Advantec oil that I used on the first 3 oil changes since my '18 GSA is still under warranty. Link to comment
MichiganBob Posted October 1, 2019 Share Posted October 1, 2019 Suspense grows........... Link to comment
realshelby Posted October 1, 2019 Share Posted October 1, 2019 8 hours ago, Endobobdds said: Look forward to the report! I am slightly overdue for my next oil change. I bought the Beemer Boneyard 4L jug of LiquiMoly a while ago for this next oil change. However after reading through this post I have been considering purchasing the BMW Advantec oil that I used on the first 3 oil changes since my '18 GSA is still under warranty. My Liqui-Moly report only showed 1 ppm of moly in it. Which is as close to none as you can get. It meets the other criteria BMW specifies. But it will be interesting to see the results from the new sample of Advantec! 1 Link to comment
longjohn Posted October 1, 2019 Share Posted October 1, 2019 13 hours ago, Endobobdds said: Look forward to the report! I am slightly overdue for my next oil change. I bought the Beemer Boneyard 4L jug of LiquiMoly a while ago for this next oil change. However after reading through this post I have been considering purchasing the BMW Advantec oil that I used on the first 3 oil changes since my '18 GSA is still under warranty. I'm still waiting for it. I called them and they said a few more days. Link to comment
longjohn Posted October 9, 2019 Share Posted October 9, 2019 On 10/1/2019 at 10:54 AM, Paul De said: Sorry. I'm a day late. I get so busy being retired. Anyhoooo. You won't believe the report : 1 Link to comment
Paul De Posted October 9, 2019 Share Posted October 9, 2019 10 hours ago, longjohn said: Anyhoooo. You won't believe the report : Haha, I am not so surprised Molybdenum was present in the Advantec Ultra oil given that virtually all of the current generation of synthetic oils contain this additive, but at more than 2x the universal average makes BMWs (Cameron's) response to BrianM bordering on disingenuous. Well the upside is that SL,SM and SN along with Liqui Moly's to the point response shared here are as safe to use as BMWs precious Advantec Ultra oil in their motors. So, what oil makes your bike shift smoother? 1 Link to comment
Dave_in_TX Posted October 9, 2019 Share Posted October 9, 2019 7 hours ago, Paul De said: Haha, I am not so surprised Molybdenum was present in the Advantec Ultra oil given that virtually all of the current generation of synthetic oils contain this additive, but at more than 2x the universal average makes BMWs (Cameron's) response to BrianM bordering on disingenuous. Well the upside is that SL,SM and SN along with Liqui Moly's to the point are as safe to use as BMWs precious Advantec Ultra oil in their motors. So, what oil makes your bike shift smoother? Add me to the list of those not surprised to see some moly in the Advantec Ultra. Link to comment
realshelby Posted October 9, 2019 Share Posted October 9, 2019 That is surprising! I would like to see what a BMW rep would say to you after seeing this! Sure makes Liqui-Moly seem to be a very good oil. I would like to see a test result of this oil with 5-7,000 miles on it to compare. Thank you for taking time and spending the money for this very conclusive report! 1 Link to comment
realshelby Posted October 9, 2019 Share Posted October 9, 2019 On 9/21/2019 at 1:40 PM, Dave_in_TX said: I only see the analysis for Molbil 1. I just realized I made a mistake in my description. The first column is listed correctly in the Blackstone report, it is Mobil 1 Racing 4T 10-40. I list this first column as "Castrol Racing 4T 10-40 " in my written description above the report. That is wrong, there is no Castrol used in the three analysis reports. I cannot go back and fix my post from 9/17...maybe a mod can? Last thing I wanted to add to an oil discussion was confusion! Link to comment
92Merc Posted October 9, 2019 Share Posted October 9, 2019 Has anyone done a "clean" oil report on the Shell Rotella T6? I'd be curious how that compares to the Advantec. I still plan on staying with Moly. But if T6 comes in the same as Advantec, it would be a good "backup" oil should I need some ASAP. 1 Link to comment
Paul De Posted October 9, 2019 Share Posted October 9, 2019 Realshelby reminds me of my lack of manners, so excuse my miss to say thanks to all who have sent oil off for testing as the data really has taken this oil discussion to another level by using data and facts and not just opinion. Good stuff! 2 hours ago, realshelby said: Sure makes Liqui-Moly seem to be a very good oil. I would like to see a test result of this oil with 5-7,000 miles on it to compare. I am not sure but I think you are referring to a used sample of Advantec Ultra. I am coming up on an oil change with Advantec Ultra in the motor so unless someone already has this data I will step up and send my used sample in. The caveat is that we are in for some snow this weekend (oof) and if they lay some salt down, it may mess up hitting the mark for mileage. Also the data I will share will be about a month out from now given my schedule. 1 Link to comment
realshelby Posted October 9, 2019 Share Posted October 9, 2019 1 hour ago, Paul De said: I am not sure but I think you are referring to a used sample of Advantec Ultra. I think the sample longjohn sent in was from a new container of that oil. From the looks of the report it was not used as there is no silicon or iron reported for instance. 1 Link to comment
Cap Posted October 9, 2019 Share Posted October 9, 2019 8 hours ago, 92Merc said: Has anyone done a "clean" oil report on the Shell Rotella T6? Yes, I posted a link on page 1 of this thread. Rotella T6 CK-4 has half the molybdenum of longjohn's Advantec. 1 Link to comment
Paul De Posted October 10, 2019 Share Posted October 10, 2019 8 hours ago, realshelby said: I think the sample longjohn sent in was from a new container of that oil. From the looks of the report it was not used as there is no silicon or iron reported for instance. Right, longjohn's sample was fresh. So, I will sample and test used Advantec so, to a degree, it can be compared to several of your samples (assumes riding conditions and our motors are wearing very similarly). Close enough for hand grenades, and horse shoes. 1 Link to comment
MichiganBob Posted October 10, 2019 Share Posted October 10, 2019 A little help here please for the aged. Is molybdenum a good thing, bad thing, neutral, or it depends on how much? For example, the post above stated that the Rotella T6 has half the moly of the Advantex. Is that a red flag or just an interesting fact. Would one want to stop using the T6 because of this? One more question. My 2018 has a bunch of warranty left on it. I had the dealer change the oil at 600 but I was going to do my own oil changes from now on. Will using something other than the Advantec void my warranty or at least raise an issue with BMW if something goes wrong with the engine? I would go with the Liquidmoly based on what I read here and save at least a few bucks. Many thanks. Michigan Bob Link to comment
Paul De Posted October 10, 2019 Share Posted October 10, 2019 Molybdenum is a common additive in the latest generation oils and I believe are added to improve antiwear properties as well as reduce catalytic converter poisoning . So generally a good thing. In theory if the oil you use meets the stated BMW specification your warranty is not voided. The problem is that BMW stated specification is confusing in that it states no molybdenum oil supplements and their CS responded here in a way that suggests no molybdenum in the oil, period. As we peel the onion, it seems that BMW's recommended labeled oil (BMW Advantec Ultra 5W-40 ) does not meet their stated specification as it contains a healthy slug of molybdenum. I guess I would avoid the added hassle of proving your alternate oil meets their spec and run Advatec Ultra until your OEM warranty expires. I you have a third party extended warranty I guess it would be prudent to verify if there is an oil clause in that policy. 3 Link to comment
Dave_in_TX Posted October 10, 2019 Share Posted October 10, 2019 If I were the poster who received the reply from BMW's CS rep, I would reply asking why their recommended oil has moly when they specially say any moly is harmful just to see what their reaction is. 3 Link to comment
Paul De Posted October 10, 2019 Share Posted October 10, 2019 2 hours ago, Dave_in_TX said: If I were the poster who received the reply from BMW's CS rep, I would reply asking why their recommended oil has moly when they specially say any moly is harmful just to see what their reaction is. Haha, At least we could get a laugh out of the pretzel logic weasel worded response that clarifies nothing! Link to comment
longjohn Posted October 10, 2019 Share Posted October 10, 2019 19 minutes ago, Paul De said: Haha, At least we could get a laugh out of the pretzel logic weasel worded response that clarifies nothing! Sadly it’s apparent that BMW uses obfuscation to pad their bottom line. Haha, they treat us like mushrooms: Kept in the dark and fed manure. 1 1 Link to comment
alexp Posted October 17, 2019 Share Posted October 17, 2019 My friend uses this oil in his bike. MOTUL 7100 10-60. I took his bike for a test and was amazed for the smooth operation. The shifting was great too. I just dont know if this is ok for the bike! It felt like a completely different bike . Link to comment
AndyS Posted October 17, 2019 Share Posted October 17, 2019 alexp, Did you take your friends bike for a ride BEFORE he put this oil in? Link to comment
MichiganBob Posted October 17, 2019 Share Posted October 17, 2019 Good Morning, The following oils/weights are mentioned in this thread: Rotella T-6 5-40 Rotella T-6 15-40 Castrol 5-40 Motul 10-40 Motul 10-60 Mobil 1 10-40 Advantec Pro 15-50 Liqui Moly 5-40 I'm interested in the variance of weights. the first weight is 5, 10, or 15. The second is 40, 50, or 60. What do you think about that folks? Link to comment
Cap Posted October 17, 2019 Share Posted October 17, 2019 Motul 4T 7100 in 5W-40 Motul makes 4T in the correct weight for our wetheads... But does it have moly? Link to comment
realshelby Posted October 17, 2019 Share Posted October 17, 2019 51 minutes ago, MichiganBob said: Good Morning, The following oils/weights are mentioned in this thread: Rotella T-6 5-40 Rotella T-6 15-40 Castrol 5-40 Motul 10-40 Motul 10-60 Mobil 1 10-40 Advantec Pro 15-50 Liqui Moly 5-40 I'm interested in the variance of weights. the first weight is 5, 10, or 15. The second is 40, 50, or 60. What do you think about that folks? I don't know about recommended. Some have said they use those weights. To be sure you are using the recommended viscosity of oil in your Wethead BMW ( this forum is the Wethead forum after all ) you simply have to be sure it is 5-40. This is the only recommend viscosity per BMW. To be sure you are using an oil that meets specifications BMW lists for your Wethead beyond viscosity.....Well that is a LOT more complicated. For instance, Shell Rotella T-6 used to meet those specifications but the new formulation does not. I tried 10-40 ( warranty is expired ) to see if it made any positive changes. It did not. I also ran Rotella T-6 for a few changes back when it was gasoline engine rated. Performed very well. Bottom line is that you are going to be hard pressed to find an oil that actually meets BMW's specifications. It seems that BMW's recommended oil, Advantec, actually has significant amounts of molybdenum in it! Considering BMW is on record stating Molybdenum should not be in oil due to it stripping coatings off engine parts, I find there is room for shall we say "clarification"! Link to comment
alexp Posted October 18, 2019 Share Posted October 18, 2019 22 hours ago, AndyS said: alexp, Did you take your friends bike for a ride BEFORE he put this oil in? No I didn't . He told me that his bike runs much better with that oil and I did ride his bike for two days and did notice a big difference! Link to comment
Skywagon Posted October 18, 2019 Share Posted October 18, 2019 Hey Alex... What bike is your friends and how many miles versus yours? On my RT it has become noticeably smoother as the miles are added. When it was new and probably for the first 12k it felt like the BMW of old...shifted in the lowest gears like a Massey Ferguson. Now that I am in the 20's it is really smooth to me...at least by BMW standards. I rarely experience any clunking. The only thing I've changed on purpose is at the speeds I downshift in the lower gears. From 3-2-1 I shift at much slower speed than I have most of my life. I shift at a speed where there is very little engine braking and it really has all but eliminated the clunking. Curious your experience. Link to comment
Rider1260 Posted October 18, 2019 Share Posted October 18, 2019 On 8/19/2019 at 2:00 PM, RecentConvert said: I don't have your model RT BUT I have had some wet clutch bikes that were not the best shifting bikes my FJ1200 Yahama was one of the worst BUT when I changed to Spectrol everything changed for the better for me. It will meet all the specs of your current bike also and more reasonable that most cycle oil. https://spectro-oils.com/golden-semi-synthetic-2/ I assume that when I purchased my '14 RT that since it had been serviced the day prior at BMW in Indianapolis, it had BMW's $16 per quart oil in it. The next oil change I switched to Castrol motocycle oil in 4T 5W40. At $9.50 per quart it was more reasonable and recommended in the manual. I continued with this oil until an unfortunate incident in Torrey in May. My RT is not a smooth shifter. 1-4 it clunks and isn't confidence inspiring. 4-5-6 is smooth as butter. I had complained loudly to BMW and they tore down the transmission and clutch while still in warranty. That proved it was in spec, it is just a poor shifting unit. As several of you mentioned, I have gotten used to the BMW way of shifting, I still don't like it, but it is my new "normal". I played with oil level at BMW suggestions and found it does make some difference if the level is lowered to center of the sight ring. Not a lot, but noticeable. In Torrey, i lost most of the oil from a punctured valve cover. Being unable to find motorcycle rated oil, we filled it with the automobile 5W40 with all of the slick additives we aren't supposed to have on a wet clutch. To say the least, I was hearing all types of ghost noises during the ride home. I was waiting for the mains to seize, etc. most were ghosts and the bike seems to have suffered no ill effects from the oil loss. What I did notice was that the shifting improved! Far more than was attained by running with a lower oil level and Castrol. Being a good engineer, I drained the automobile oil as soon as I got home and refilled with Castrol. The shifting went back to normal. Having read many of the oil threads, the use of Rotella T6 5W40, caught my eye. I can get that anywhere from almost any convenience store in case of emergency. At $20 per gallon my wallet liked it, and it is JASO and JASO2 rated. So I switched during the last oil change. The changes were immediately noticeable! Valve clatter is nearly gone! I only heard it around town and without a helmet, but now it is absent. I don't know if that is a good thing, but I like it. The second change was poorer shifting! Definitely not something I needed or wanted! I have only 1000 miles on this oil change so I will leave it in the engine until after Torrey. I will be going back to Castrol, but if clutches were cheap and easy to fix, I really liked the automotive oil shifting properties! ' Link to comment
dirtrider Posted October 18, 2019 Share Posted October 18, 2019 32 minutes ago, Rider1260 said: I don't have your model RT BUT I have had some wet clutch bikes that were not the best shifting bikes my FJ1200 Yahama was one of the worst BUT when I changed to Spectrol everything changed for the better for me. It will meet all the specs of your current bike also and more reasonable that most cycle oil. https://spectro-oils.com/golden-semi-synthetic-2/ Evening Rider1260 BMW 1200 wethead oil spec is 5w40, I don't see that listed in the info at your Spectro-oils link. Link to comment
strataj Posted October 18, 2019 Share Posted October 18, 2019 39 minutes ago, dirtrider said: Evening Rider1260 BMW 1200 wethead oil spec is 5w40, I don't see that listed in the info at your Spectro-oils link. I haven't heard the name Spectro in a long time. Look here https://spectro-oils.com/platinum-full-synthetic-4/ Link to comment
Paul De Posted October 19, 2019 Share Posted October 19, 2019 5 hours ago, strataj said: I haven't heard the name Spectro in a long time. Look here https://spectro-oils.com/platinum-full-synthetic-4/ And the LSP454 actually meets the printed specification 5W-40 API SL JASO MA/MA2 Link to comment
Rider1260 Posted October 19, 2019 Share Posted October 19, 2019 6 hours ago, dirtrider said: Opps I posted the wrong link , others found the Platinum line that has the right spec , there was a post someplace that BMW branded oil was Spectro looks like they also have the trans and final drive oil. 6 hours ago, dirtrider said: Evening Rider1260 BMW 1200 wethead oil spec is 5w40, I don't see that listed in the info at your Spectro-oils link. Link to comment
dirtrider Posted October 19, 2019 Share Posted October 19, 2019 7 hours ago, Rider1260 said: Opps I posted the wrong link , others found the Platinum line that has the right spec , there was a post someplace that BMW branded oil was Spectro looks like they also have the trans and final drive oil. Morning Rider1260 What is the correct link as it looks like the Spectro L.SP454 Platinum line does seem to meet the wethead BMW 5w40 spec but at $17.00+ per quart that falls short in your mentioned "more reasonable than most cycle oil" category. Link to comment
Paul De Posted October 31, 2019 Share Posted October 31, 2019 On 10/9/2019 at 9:09 AM, Paul De said: I will step up and send my used sample in. The caveat is that we are in for some snow this weekend (oof) and if they lay some salt down, it may mess up hitting the mark for mileage. Also the data I will share will be about a month out from now given my schedule. Well folks I have not forgotten my promise, but the delay may be longer. Wasn’t close to useful mileage yet and Mother Nature curbed my sorry riding butt with multiple inches of snow in these parts. With the obligatory salt they put down, I will need for a melt and good rain. ETA is now uncertain Link to comment
Hosstage Posted November 2, 2019 Share Posted November 2, 2019 On 8/19/2019 at 7:10 PM, 041100S said: Just to add a little to the discussion, I purchased a '16 R1200RS and the previous owner was running Motul 7100 10w-40 4T, this is a JASO MA-2 rated. So far everything is good with the bike and shifting is easy, that is not hard shifting. However, this oil is also over $10 per liter so pretty high. On my next oil change I plan to go with Castrol Power 1 5w-40 which is also JASO MA-2, APL-SL rated. This oil can be purchased from Amazon for about $9 per quart or about $9.50 per liter. I will try it and if shifting becomes hard go back to Motul. I'm a little confused. The Motul is working well, but costs $10 per litre, so you're going to switch to oil that may or may not work as well to save 50 cents per litre, 2 whole dollars per oil change? $10 is expensive, but $9.50 is not? Link to comment
Paul De Posted November 2, 2019 Share Posted November 2, 2019 1 hour ago, Hosstage said: I'm a little confused. The Motul is working well, but costs $10 per litre, so you're going to switch to oil that may or may not work as well to save 50 cents per litre, 2 whole dollars per oil change? $10 is expensive, but $9.50 is not? Likely a very safe switch as the Castrol Power 1 5W-40 was the recommended oil until BMW entered into a contract with Shell to make their branded oil Advantec Ultamate 5W-40. If the he gets improved shifting then it was worth the change at near zero risk. While 041100S' bike is outside of the OEM warranty, given the confusing specification and data collected here, if your bike is still under the OEM warranty I would grumble under my breath and stick with the Advantec Ultimate to avoid any weasel room on BMW's side. Link to comment
Cap Posted November 2, 2019 Share Posted November 2, 2019 1 hour ago, Hosstage said: I'm a little confused. The Motul is working well, but costs $10 per litre, so you're going to switch to oil that may or may not work as well to save 50 cents per litre, 2 whole dollars per oil change? $10 is expensive, but $9.50 is not? Castrol 4T is generally available for about $7.50 per quart. But I agree with your point that the difference in price is pretty small in absolute terms. Even Rotella T6 at $20 per gallon represents only a $20 difference in cost for an oil change. I think most of us want to find something that works well, meets the BMW spec, and costs as little as possible. One thing that has surprised me is the difference in shifting characteristics between several of these different brands of oil. This thread prompted me to try a few brands mentioned here, and pay more attention to the shift-feel. I found some large differences in feel. And this "shift feel" is pretty personal -- I have discussed it with friends, and discovered that some things that bother me feel normal to them. So my take-away from this great thread is that I will continue to try different brands of oil until I settle on one that gives me the shift-feel that I like best. Link to comment
WBinDE Posted November 3, 2019 Share Posted November 3, 2019 Coming back late to this discussion, but I'd be cautious about this assertion: On 9/17/2019 at 5:19 PM, realshelby said: Mobil 1 with 4ppm compared to LM with 3ppm might not seem like much, but the 4 is 33% more wear metal in the oil than the 3 of the LM. In scientific measurements there is a difference between "3" and "3.0", having to do with how precisely the number is known. While @realshelby's statement is technically correct, in reality "3" just means somewhere between 2.6 and 3.4; likewise "4" means somewhere between 3.5 and 4.5. So the real difference between the two could be anywhere from 1.9 (i.e. one is 73% higher than the other, a huge difference) to 0.1 (3%, an insignificant difference). The precision of the measurement isn't high enough to say with confidence that there is a significant difference between the numbers, and one should be cautious about drawing firm conclusions on that basis. Link to comment
92Merc Posted November 10, 2019 Share Posted November 10, 2019 So, I was watching some unrelated Youtube video's on engine oil. Amazon Basics actually out performs many "big brand" oils. Anyone want to send this off to Blackstone?? https://www.amazon.com/AmazonBasics-Full-Synthetic-Motor-Oil/dp/B07CCHLLRL/ref=sr_1_4?keywords=amazon+basics+diesel+oil&qid=1573408971&sr=8-4 Link to comment
