neil_wilcox Posted August 15, 2019 Share Posted August 15, 2019 I installed the fuel strip emulator from HPoskam engineering recently while I was doing a brake flush ( 2005 RT ) and had the gas tank off. My fuel strip failed years ago and I was tired of looking at the yellow warning triangle all the time while riding. The little device is a plug and play install and it worked perfectly in a matter of about 20 seconds after turning on the ignition. Now the fuel level always shows full and the miles to empty are displayed again. Of course, I have to use the tripmeter in order to monitor my fuel range but I had already been doing that for a long time and I was used to doing that with older bikes anyway. A big thanks to whoever mentioned this device on this forum in the past. Neil Wilcox Link to comment
Beech Posted January 9, 2020 Share Posted January 9, 2020 Got this off another forum from a very knowledgeable fellow. Looks like a solution to the fuel strip problem. https://www.ukgser.com/forums/showthread.php/509657-Fuel-strip-to-float-conversion-complete-guide Link to comment
